0 registered (), 136 Guests and 0 Spiders online.
#430140 - 25/05/05 07:21 PM Pics of the PML
Hello All,
I was fortunate enough to have my wife's 2002 Saturn L100 rear-ended and totaled a couple of weeks ago by some typical sorry-a$$ SoCal driver. I say "fortunate" because we now have a 2003 4x4 X we were able to pick up with the insurance money. I'm looking at doing the Poor man's lift, but it's hard to imagine what the 1.5" lift would look like.
Could people post pics of their PMLs in this thread so I could get an idea?
I did a search and got less than stellar results.
Thanks in Advance!
ted
#430141 - 26/05/05 01:20 AM Re: Pics of the PML
also search the picture forum with varios spellings:
pml
poor man lift
poor mans lift
poor man's lift
1.5 lift
shackle lift
t bar lift
torsion bar lift
#430142 - 26/05/05 05:34 AM Re: Pics of the PML
The absolutely BEST way to see how you would look with a 1.5" lift, assuming you can't just imagine the tires staying on the ground, and the rest going up 1.5"...is to measure the wheel well peaks at all 4 corners, and then, put a jack under the truck, and jack up 1.5", with jack stands as needed if no floor jack..etc.
Then stand back, and look at the truck from all angles....that's it...exactly what YOUR truck will look like.
(It will look about the same, but 1.5" taller if that saves you any time.)
wink
Other trucks have different sized tires, especially after the PML...so the tire/well spacing won't look like your truck anyway...but, if you are also doing an upsize on the tires, that might be ok.
Good Luck!
#430143 - 26/05/05 06:50 AM Re: Pics of the PML
i'll tell you right now, funk, if personal testimony counts for anything, the poors man's lift makes a big difference. I put it on, and then had to take it off, and it made a huge difference: the way it looked and the way it rode. I love the way the X looks with the PML. And most other people notice the difference, too. For 50$, its unbeatable.
My PML was the reason i bought my 3" lift.
#430144 - 26/05/05 11:52 AM Re: Pics of the PML
By this do you mean it had a negative effect? Or are you just stating that there was a difference in the ride. I'd assume maybe its more jittery, handling is changed by center of gravity being higher, etc...
#430145 - 26/05/05 01:04 PM Re: Pics of the PML
He took it off because the dealer would not work on it with the shackels on. Since the dealer thought that the shackels had something to do with a rock finding its way into the lower control arm.
#430146 - 26/05/05 01:11 PM Re: Pics of the PML
Good Luck!
Yeah, I was thinking of maybe getting 16X8 steel wheels and 265/75 All terrains. Unfortunately I do not yet have a jack or stands, so I'll have to rely on other's pictures.
Navy, I'll give those search words a try.
Thanks,
Ted
#430147 - 26/05/05 01:16 PM Re: Pics of the PML
Make SURE you get rims with 5.25" of backspacing...if you get rims with less backspacing, you will get WAY more tire rub...I can't stress this enough (unles you listen, and then I guess I could...).
#430148 - 26/05/05 01:19 PM Re: Pics of the PML
A ROCK!! IN MY LOWER CONTROL ARM! TWO WEEKS THE DEALER HAD MY TRUCK, AND THEY FOUND NOTHING! 30 MINUTES AT MY PARENTS MECHANIC, AND THEY FOUND THE ROCK AND REMOVED IT!! idiots...
I wish i hadn't fallen victim to the "we can't work on your car due to aftermarket products added to the suspension" BS...
regardless, now i'm ready for the 3" lift.
the shackles made a huge difference in the ride height, and its noticeable, absolutely. As for the comfort of the ride, the change is negligeable (sp?).
any further questions for me, please direct them to my spokesperson, schteve...
#430149 - 26/05/05 01:38 PM Re: Pics of the PML
Jake will not be taking any more questions...
please move on, nothing to see here.
#430150 - 26/05/05 04:21 PM Re: Pics of the PML
Still no Pics? I did the ten different searches Navy, and got some decent pics... I guess.
[QB]Make SURE you get rims with 5.25" of backspacing...QB]
I was looking at either
AR 767 15x7 4" bs w/ 31x10.5r15 tires
or
US Wheel 84 16X8 5" bs w/ 265x75x16 tires
Do you think I'd have any problems fitting one or the other under a t-bar twist and calimini shackles?
Thanks.
oh, it's an '03 4x4
#430151 - 26/05/05 07:29 PM Re: Pics of the PML
i just did my PML (or in my case, the PWL smile ) this afternoon.. it was really easy- thanks to finallyanxer for so graciously ignoring his work to help me when i ran into a pickle via AIM.. the front took me all of 20 minutes to raise- and the rear took a little longer because im a n00b and couldnt figureo ut how to lower my spare tire [Too much XOC] all in all, took me about 1.5hrs to do everything..
btw- the front now sits at 34" from ground to TDC of the wheelwell.. and 36" in the rear.. it actually turne dout to be more like a 2" lift all around instead of a 1.5.. dont know why, but it did..
#430152 - 26/05/05 09:32 PM Re: Pics of the PML
Here's a few PML pics. Used the calmini shackles for 1.5 lift overall. Front came up a bit under, though, but I've taken it out in the rough fully loaded and appreciated having a bit of the factory rake to compensate for the extra weight.
Saving up for a new set of tires, now.
#430153 - 27/05/05 08:21 AM Re: Pics of the PML
FinallyAnXer Offline
Loc: Bradford, PA
lol.. glad I could help! Betcha yer glad you didn't send the shackles back.
Looks nice! Now tires. smile Stick with the 15"s Get some 31x10.5x15s.
15"s will be cheaper and give ya more rubber between the road and the rim, giving better ride.
-Jeremy
"I'd like to move us right to Peter Gibbons. We had a chance to meet this young man, and boy that's just a straight shooter with upper management written all over him." - Bob Slydell (Office Space)
#430154 - 02/06/05 07:02 AM Re: Pics of the PML
Shackle lift and 32x11.50 BFG's
#430155 - 02/06/05 07:33 AM Re: Pics of the PML
If you must get new rims, the 5" BS are close enough to the 5.25" BS you really want to work.
#430156 - 02/06/05 08:03 AM Re: Pics of the PML
......doing an upsize on the tires....
Definitely upsize and get some All-terrains. The PML looks gay with stock road tires.
My rendition:
#430157 - 02/06/05 09:29 PM Re: Pics of the PML
Super PML
$50 or about $10 if you go get some 3/8 bar stock and a few bolts. Drill two holes in each of the four bars and you're done. Not that nice powdercoated blue, but it fit a college budget. I sprayed mine with a good undercoating.
#430158 - 03/06/05 06:19 PM Re: Pics of the PML
Thanks for the info and the pics everyone.
Now, how about the spare? Are you guys running "31 or 32" inch tires on stock rims able to fit your spare in it's stock location? It looks like it'd be a tight fit. Should I post this question in the tire forum?
