0 registered (), 116 Guests and 0 Spiders online.
#430365 - 03/09/07 05:45 PM Shakle Bolt question.
I had a post earlier about this but never resolved the issue. I was given a set of SLR shackles im guessing 1 inch. They are about an inch longer to the eyeholes.
I need the bolts and sleeves. I am assuming the sleeves from the sotckers will work???
Considering the bolts from SLR are 25 plus 8 for shipping, is there another avenue i can take to get the bolts?
The shackle pieces are about an inch longer between the boltholes, this will allow me about 1/2 inch of lift?
Thanks for any help
Jay
#430366 - 03/09/07 06:01 PM Re: Shakle Bolt question.
TSC or ace hardware, around me ACE is the place for hardened bolts.
#430367 - 03/09/07 06:23 PM Re: Shakle Bolt question.
So if i can get grade 8 bolts i can re-use the sleeves from the stockers?
What about bushings i saw on slr website poly shackle bushings..
#430368 - 03/09/07 06:59 PM Re: Shakle Bolt question.
One inch of extra shackle length, center of eye to center of eye, gives 1/2" of lift.
The OEM shackles are about 3" long, so 4" long (eye to eye...) gives 1/2" of lift, etc.
#430369 - 04/09/07 05:06 PM Re: Shakle Bolt question.
Cool the stockers i measure at 3 1/4 and the slr ones i got are at 4 1/2 which is about 5/8" of lift.
Odd measurment though on the SLR's there site only shows a 1" and 2" i guess these are the 1"
So this would put the front well tops at 34 1/2 and the backs at 36 3/8
almost a 2" rake??? Will that look funny? Anybody got a pic of a similar setup?
Jay
Are the poly slr shackle bushings worth the extra 10 bucks?
#430370 - 10/09/07 04:27 PM Re: Shakle Bolt question.
I ordered the bolts, busings and center crush pieces. All told they are $47 to your door.
Hope they only take 15 minutes a side to install as someone stated on one of the threads.
#430371 - 11/09/07 04:38 AM Re: Shakle Bolt question.
marmillerX Offline
Loc: Shrewsbury, MA
It should take 15min unless your like me and had the bushings fused onto the spring pack. mad Start hitting everything with PB Blaster. Good luck.
#430372 - 14/09/07 02:12 PM Re: Shakle Bolt question.
OK so i got the bolts today. one is just a bolt the other one has bushings and a sleeve on it. Is that correct? SHould they both have bushings and sleeves?
