182
#43559 - 06/02/05 12:25 PM
Camper Towing
Hello everyone, I want to get your opinions about towing. My X is an 04 5sp 6cyl. The popup I just bought weighs in at 1670lbs dry. Im figuring an extra 400lbs for gear, food, ect. I know that the tow limit is 3500lbs for a manual tranny. My question is, are there any tricks or things that I should know about towing this trailer. My X will be wired with a electronic brake controller. Im expecting my mileage to drop to about 10mpg from the 17mpg im getting now.
#43560 - 06/02/05 12:45 PM
Re: Camper Towing
Loc: Shohola,PA. 18458
Should be no problem towing the pop-up. Your mileage should not drop hardly at all; you are not towing a trailer that causes any wind resistance, so the mpg should not drop. Good luck!
#43561 - 06/02/05 01:30 PM
Re: Camper Towing
Originally posted by buck: Should be no problem towing the pop-up. Your mileage should not drop hardly at all; you are not towing a trailer that causes any wind resistance, so the mpg should not drop. Good luck! His mileage will drop, but I agree that a trailer of that size shouldn't pose any special challenges. Don't slip the clutch too much and you should be fine.
#43562 - 06/02/05 06:49 PM
Re: Camper Towing
Loc: Loganville,Georgia
My mileage drops to about 8-10mpg when towing my pop-up. But then it does weigh 4200lbs. loaded.
#43563 - 08/02/05 08:45 PM
Re: Camper Towing
The secret to towing with a small engine is use rpms.. never let it lug down. If you are climbing any kind of a hill stay up above 3000. Also use your gears going down and save the brakes. I have put 300,000 miles on Nissans and never lost an engine. Enjoy.. Mojave
#43564 - 15/02/05 08:24 PM
Re: Camper Towing
Loc: Yarnell, AZ.
We tow a 1000 lb 13 ft. Burro. By the time we load all our crap, it's probably up to 2500lb. Tows fine but the mileage drops to 12-13 mpg ,depending on wind and how fast you want to travel.
"What's the point in going out? We're just going to end up back here anyway" H. Simpson
#43565 - 16/02/05 09:02 AM
Re: Camper Towing
For the outlay of $70 you can put a friction sway control on which gives a bit if extra security (in the dry). I'm not sure the X needs one but since I started out towing using a Jeep Wrangler I rapidly came to appreciate them!
Blizzard - I hope you're exaggerating about the 2500lbs. At best the axle on a Burro will be rated for 2200lbs, when new, & even if you are running ST175/80R-13(C)s you'll be getting close to the 2700lbs max combined loading. Burro's have a habit of cracking the frame too.
#43566 - 16/02/05 09:11 AM
Re: Camper Towing
You have a link for the sway control?
#43568 - 16/02/05 06:31 PM
Re: Camper Towing
Loc: Yarnell, AZ.
Blizzard - I hope you're exaggerating about the 2500lbs. At best the axle on a Burro will be rated for 2200lbs, when new, & even if you are running ST175/80R-13(C)s you'll be getting close to the 2700lbs max combined loading. Burro's have a habit of cracking the frame too.[/QB][/QUOTE]
I'm talking about all the crap we load inside the Xterra , not loading the Burro that much.Can't put much inside anyway. Just guessing on the wt.
#43570 - 17/02/05 06:12 AM
Re: Camper Towing
Originally posted by blizzard: Blizzard - I hope you're exaggerating about the 2500lbs. At best the axle on a Burro will be rated for 2200lbs, when new, & even if you are running ST175/80R-13(C)s you'll be getting close to the 2700lbs max combined loading. Burro's have a habit of cracking the frame too. I'm talking about all the crap we load inside the Xterra , not loading the Burro that much.Can't put much inside anyway. Just guessing on the wt.[/QB][/QUOTE] OK that's cool. BTW we have a 13' Scamp, great little thing.
#43571 - 23/02/05 05:11 PM
Re: Camper Towing
Ok my girlfriend has a 2000 X 4cylinder 5 speed, would she be able to trailer a horse trailer with 2 horses in it? It would probably be 4000lbs
#43572 - 24/02/05 05:18 AM
Re: Camper Towing
Originally posted by kintetaylor: Ok my girlfriend has a 2000 X 4cylinder 5 speed, would she be able to trailer a horse trailer with 2 horses in it? It would probably be 4000lbs You might go faster if the two horses pull the 4-banger. I'd seriously question the sanity of towing 4K lbs with a 4 cylinder.
