#45334 - 09/04/05 06:47 PM AFTERMARKET CALMINI TRE's
Let me start off by saying I DID SEARCH!!! Although my search did not find me the information i was looking for.
Ok, here is the question, so bear with me
I have a calmini steering kit and want to change out my stock outer TRE's with a bit more beafy set.
Can anyone tell me what the Mcquay Norris or MOOG part number is for the outer TRE's that are 11/16 and 4130 alloy? I want to swap my stock outer TRE's out before GONE.
< Disclaimer for all the XOC Guru's... Yes after posting this I realize I probably shouild have listed it in the suspension section>
#45335 - 09/04/05 07:54 PM Re: AFTERMARKET CALMINI TRE's
ShipRekd1 Offline
Sure looks like they are using the Moog # as their part number...just drop the NP
On their siter NPES409R should be moog ES409R...........
http://www.purenissan.com/tie_rod_ends2.htm
#45336 - 09/04/05 10:51 PM Re: AFTERMARKET CALMINI TRE's
XSAL Offline
Loc: 94043 -> 19355
Those are tie-rod ends used for the centerlink...at least for the Calmini steering system.
I don't know if Mcquay Norris and Moog share the part number, but I just bought a couple of Mcquay Norris ES409R to replace the tie-rod ends for the centerlink... :rolleyes:
I also wanted find less expensive and beefier one for replacing the stock inner/outer TRE. I couldn't find one on time... [Uh Oh !]
#45337 - 10/04/05 09:59 PM Re: AFTERMARKET CALMINI TRE's
Yes its the outers I am looking to replace myself
