0 registered (), 104 Guests and 0 Spiders online.
#45407 - 07/07/04 02:16 PM 00 3rd gear slipping
has anyone had a problem with slippage while in 3rd gear? either when i'm braking or accelerating while in 3rd gear, it sometimes just pops out and goes into neutral. i have a lot of "play" with that gear - when it's engaged, it moves around a lot.
i hate to go in to get it fixed with such a vague problem. any help is appreciated.
thanks!
#45408 - 08/07/04 08:32 AM Re: 00 3rd gear slipping
sandmanX Offline
Loc: Ridgecrest California
Synchro problem?
gazeinwidewonder | flickr | geocaching
#45409 - 08/07/04 09:06 AM Re: 00 3rd gear slipping
thanks, but i'm not sure what that means. could you explain?
#45410 - 08/07/04 11:34 AM Re: 00 3rd gear slipping
xterra3202 Offline
Loc: Georgia
synchros basically are what eliminates double clutching. they allow the gear and the collar to make a smooth connection at the same speed before the dog teeth actually engage the gear. simply put your tranmission needs to looked at by a good mechanic and parts will more than likely have to be replaced. hope this helps.
Tim
Thomas Jefferson
#45411 - 08/07/04 11:36 AM Re: 00 3rd gear slipping
xterra3202 Offline
Loc: Georgia
since your in Colorado Springs try Academy Nissan first for a diagnosis then once you know what parts you need find a shop to do the work for you. firestone at rangewood and woodmen does good work not sure if they do transmissions but give them a call anyway!!!
Tim
Thomas Jefferson
#45412 - 08/07/04 11:38 AM Re: 00 3rd gear slipping
thanks so much!
#45413 - 08/07/04 11:47 AM Re: 00 3rd gear slipping
xterra3202 Offline
Loc: Georgia
Anytime just ask.!!!
Tim
Thomas Jefferson
