#45707 - 25/02/05 07:53 AM Size on Plug
I have a 00 x with lsd. what tools do i need to change the diff? What wrench size? Looked under the veh the other day and it looks like its needs a hex wrech to open.
#45708 - 25/02/05 08:59 AM Re: Size on Plug
To change the diff fluid you mean? Check the backyard mechanic section, there's a how-to posted in there somewhere, but you just need a 1/2-inch-drive breaker bar to open the plugs. Remember, fill plug first, THEN drain plug...
#45709 - 25/02/05 10:04 AM Re: Size on Plug
Kaiser Offline
[ThumbsUp]
To clarify (this seemed really weird to me the first time) - you just stick the 1/2" square post from the socket wrench (or extension, or breaker bar) in the drain/fill plugs directly... just like you were putting it on a socket.
#45710 - 25/02/05 10:53 AM Re: Size on Plug
Kerensky97 Offline
Loc: Utah
Seems like somebody posted a special adapter for the 1/2" drive that was squared off specifically for situations like these. I've been looking for one since because the typical 1/2" breaker bar is slightly rounded and the plug seems to be a fraction larger than than 1/2"
-Dustin
Xterra101.com
#45711 - 25/02/05 11:18 AM Re: Size on Plug
Well, yeah, it's not an exact fit, but it works, and the guys at the dealership don't use an adapter either.
#45712 - 25/02/05 01:59 PM Re: Size on Plug
Thanks for the help, people.
#45713 - 01/03/05 07:00 AM Re: Size on Plug
You'll be looking for a Pipe Plug Socket (Male). I've seen them listed at 1/2" & 13.1mm on places like this http://www.thetoolwarehouse.net/ I don't know what the actual size you would need is, it would be one of those two.
