#45848 - 29/09/06 04:03 PM Dancing Shift Lever
Hey guys,
I have a weird one. My transmission shift lever dances back and forth while it's in third grear. It does it at around 1500rpm-28Km/h. Does anyone else have this problem? My dealer said "that is normal operations for this vehicle".
#45849 - 29/09/06 04:53 PM Re: Dancing Shift Lever
Mine did that... except in first gear for about a month then my tranny grenaded. Not to freak you out [Uh Oh !] or anything. Good luck and five speed! [drink]
#45850 - 29/09/06 05:44 PM Re: Dancing Shift Lever
01SalsaXterra Offline
Loc: Suffolk County,NY,USA
Mine has done that, especially while in 4 wheel low.
It should be normal.
I have 103k miles on my truck.
I got "IT" from ebay.
Now it burns when I pee..
#45851 - 02/10/06 10:24 PM Re: Dancing Shift Lever
ChuckH Offline
Some movement would be considered normal, but if it's really moving then you may have a new transmission in your future. Synchro failure seems to be a sore spot with these trannies, at least in small numbers.
#45852 - 03/10/06 02:32 PM Re: Dancing Shift Lever
RangerX Offline
Loc: Puyallup, WA
Another option is your engine mounts. When an engine mount has failed, your shifter will rock from left to right when the engine is under hard torque.
Shift_Faster
#45853 - 03/10/06 02:47 PM Re: Dancing Shift Lever
X2 if you wheel it and take a hard hit it can break it.
Have someone watch the engine while you rev it a little in drive. Also it is normally the mount on the drivers side.
#45854 - 10/10/06 12:38 AM Re: Dancing Shift Lever
guys is 1500 rpm hard torque... im not being sarcastic i really dont know just wondering
#45855 - 10/10/06 07:43 AM Re: Dancing Shift Lever
Rickster43 Offline
Loc: San Antonio,Texas
Yup...happened to me recently...noticed the X was very sluggish (especially uphills and Left Turns), and also noticed my Shift Lever rockin around...took it to Nissan, and they found the X had a driver's side broken engine mount, and ripped air duct hose (which was causing the sluggish )....
Your Personal CADD Monkey...
