0 registered (), 142 Guests and 0 Spiders online.
#46209 - 08/05/08 07:47 PM Rear wheel bearings and seals questions
Was wondering if anyone has had trouble with the rear wheel bearings and seals on the 05+ Xterra's. I have a 07 OR and have had to have both driver and passenger side replaced, one side at about 25k miles and the other about 31k miles. Just wondering if there is an issue with these parts?
#46210 - 10/05/08 11:41 PM Re: Rear wheel bearings and seals questions
05 s model with 96,000 miles on it. no problems with that but would like to know what the simptoms are?
#46211 - 11/05/08 07:22 AM Re: Rear wheel bearings and seals questions
Interesting. I just had the entire rear axle assembly replaced on my 06 as a warranty job. The pinion seal and bearing were shot, but the dealership decided it would be easier and wiser to just replace the whole unit.
#46212 - 11/05/08 09:16 AM Re: Rear wheel bearings and seals questions
"Easier" = They don't know how to rebuld a differential.
#46213 - 11/05/08 09:29 AM Re: Rear wheel bearings and seals questions
The seals failed, which usaully indicates that the bearings are gone. The seals leak differential fluid onto the rear rotors and rim. Makes a mess.
#46214 - 11/05/08 02:31 PM Re: Rear wheel bearings and seals questions
thanks, with 96,000 miles the only issues have been: carbon canister (fuel system)valve failed, and around 84,000 had weird sound that i thought was the pulley, turned out to be the chain guide, replaced everything under extended warranty (2,500). currently having issues with fuel system- gauge not working. overall i really drove this truck all over the country under rough highways and i am very happy. i look forward to purchasing a replacement xterra when i am able to.
#46215 - 12/05/08 02:55 PM Re: Rear wheel bearings and seals questions
I wouldn't allow the dealer to rebuild the diff anyway. I'd fight for a trans shop with diff experience to do it right the first time, which is probably why Nissan opts to replace the entire rear axle. They also decided they didn't want the old unit back, so I'm picking it up tomorrow morning to rip it apart for laughs and see what shape the pinion set and the spider gears are in.
#46216 - 13/05/08 04:01 PM Re: Rear wheel bearings and seals questions
Stonecoldchavez Offline
Loc: New Jersey
Hhhhmmm, strange. If it is a warranty repair, they have to send the rear back to Nissan.
S.
#46217 - 13/05/08 06:40 PM Re: Rear wheel bearings and seals questions
That's what I thought as well, but it was headed for the dumpster.
#46218 - 14/05/08 04:20 PM Re: Rear wheel bearings and seals questions
Loc: New Jersey
Shoot, take it then and have at it.
S.
#46219 - 14/05/08 06:47 PM Re: Rear wheel bearings and seals questions
It sits in the garage as we speak. Damn thing is heavier than it looks too.
