#492924 - 09/09/09 10:56 PM 4wd light issue
Mudlvr37 Offline
Loc: New Brunswick, Canada
I've got a 2000 Xterra and the 4wd light stays on while in 2wd. Tried backing up and no go....now here's the kicker. If I switch it into 4wd it goes out. Any ideas are much appreciated.
#492927 - 10/09/09 07:00 AM Re: 4wd light issue [Re: Mudlvr37]
granitex Offline
Loc: Columbus. Oh
you have damaged the wires going to the sensor on the side of the transfer case. Most likely right at the sensor, it is on the passenger side and there is a short in it somewhere.
Backing up only deals with the hubs, not the transfer case. The light is only a reminder, not an indicator. When you pull the lever and put it in 4h or 4l it is a mechanical linkage on the first gens.
Mine used to come on when it was really wet out, but the wires are compleatly off now and I have not had the indicator light for several years. It does not impact the function of the transfer case one bit.
#493025 - 19/09/09 03:59 PM Re: 4wd light issue [Re: granitex]
Mudlvr37 Offline
That's great. Thanks!
