182
#493602 - 28/10/09 07:17 PM
Re: Distributor or Timing Belt
[Re: therob]
Nissan Guru
Loc: Denver, CO
Verify that there's fuel pressure. Sputtering and dying sounds like a fuel or ignition issue, not a timing belt.
When the belt goes, it just shuts off. There's not if's and's or but's! Then when you go to start it, there won't be anything but hearing it turn over.
To verify the t-belt hasn't snapped or stripped, take off the distributor cap. Notice where the rotor is pointing. Use a bungy cord or some tape and secure the cap away from the rotor so that when the rotor turns, it won't hit the cap. Now, go inside the X and turn the engine over (like you're trying to start it) for just a second. Now get out and look at the rotor and see if it's pointed to a different spot. If it is, then the t-belt is still attatched and turning the cams.
Also, while you're turning the engine over, listen for a snapping sound. This will be the coil firing and the snap will be the spark. If you're getting a spark, chances are good that the ignition is good.
It would probably be easier to have someone turn the engine over so you can watch the rotor turning and listen for the snap.
One last thing to verify the engine is in time is to (while the cap is off) turn the engine over (either by hand or with the starter, but using the starter will be harder) and place the rotor to point towards the #1 spark plug wire. Now see if the timing mark on the crank pulley is close to Zero. If so, then you're engine timing is OK. If not, then the cam/crank timing is off and the timing belt has probably jumped (which would allow the distributor to still turn, but nothing is in correct time, put on a new belt and see if it still runs!).
But, I'd double check the fuel pressure as well. You might be able to hear the pump, but it may not be getting enough juice to be able to produce any pressure (i.e. bad sending unit).
Edited by Cyclemut (28/10/09 07:18 PM)
Hope line and sinker.
How's that hopey changey thing working for you?
#493640 - 02/11/09 04:28 AM
[Re: therob]
Loc: St. Martinville, LA
The local dealer was about 40 percent higher so, I'll order the kit along with a new cv boot and a couple other things I've been needing.
Thanks for all the help, 'preciate it.
Rob I am in the same boat. My distributor went out two weeks ago. Replaced it. I check with my local mech. to get a price on swapping out the timing belt and water pump. He came back with a price of $550. A little high. He is using the local dealership for parts. I am going to suggest to him that he order the kit from Courtesy and give me his usual markup. That way I will save a few dollars and he will still get is money, if I am lucky. My truck is a 2000 4x4 with 137000miles. I am on borrowed time with the timing belt.....
2000 SE 4x4 (good bye) Super Black 2007 Quest SL 2011 Titan CC Pro-4x (Smoke) "The difference between death and taxes is death doesn't get worse every time Congress meets." -- Will Rogers (1879-1935)
#493742 - 09/11/09 06:07 AM
[Re: therob]
Loc: Albuquerque, NM
