Problem posting?
11/06/24 10:33 AM
11/06/24 10:32 AM
0 registered (), 193 Guests and 1 Spider online.
#493628 - 31/10/09 10:26 PM Rear Diff Drain Plug
ripcurl2151 Offline
Loc: NJ
I just wanted to confirm that the rear diff drain plug is supposed to be a 1/2". I'm trying to change some of my fluids, and a 1/2" driver worked on everything but that plug. The 1/2" was too big, but a 3/8" was too small. I'm thinking that it got mashed up good from being dragged over some rocks. Maybe try vice grips? Any other ideas?
"If you want the ultimate thrill you have to be willing to pay the ultimate price"
#493633 - 01/11/09 02:40 PM Re: Rear Diff Drain Plug [Re: ripcurl2151]
Cyclemut Offline
Nissan Guru
Loc: Denver, CO
Yep, 1/2". You probably will need to clean out the opening with a dremel or a chisel to get the tool in there. It happens.
Hope line and sinker.
How's that hopey changey thing working for you?
#493718 - 07/11/09 05:40 AM Re: Rear Diff Drain Plug [Re: Cyclemut]
ripcurl2151 Offline
Loc: NJ
Thanks, that's what I thought.
#493779 - 10/11/09 10:31 PM Re: Rear Diff Drain Plug [Re: ripcurl2151]
miskywhisky Offline
Actually its 13.1mm. A pain in the ass to find but a company called facom makes them. It says on it "d105-13.1mm" the 1/2 works for MOST people but if you are having troubles and its starting to round inside the plug this is the RIGHT tool.
#493780 - 11/11/09 05:16 AM Re: Rear Diff Drain Plug [Re: miskywhisky]
Cyclemut Offline
Nissan Guru
Loc: Denver, CO
Hmm....
After 15 years of working on 'em, still never needed a special tool for that.
#493812 - 13/11/09 04:00 PM Re: Rear Diff Drain Plug [Re: Cyclemut]
GrnXnham Offline
Loc: Tacoma, WA
13.1?
Couldn't you just squeeze a 13mm on there by pushing really hard?
2002 Xterra XE 190K
2012 Frontier S 64K
2007 Toyota Tundra 103K
#493814 - 13/11/09 04:37 PM Re: Rear Diff Drain Plug [Re: GrnXnham]
ripcurl2151 Offline
Loc: NJ
I just squared mine off a bit with a screwdriver and pounded the 1/2" in there a little. took a couple minutes, but it did the trick
#493816 - 13/11/09 07:32 PM Re: Rear Diff Drain Plug [Re: ripcurl2151]
Cyclemut Offline
Nissan Guru
Loc: Denver, CO
Screwdriver/chisel FTW!
