#49373 - 11/07/05 02:29 PM Motor mount is a 4 letter word
Broke another one! Nissan fixed the last one under warrenty. Wish me luck on this one.
#49374 - 11/07/05 03:28 PM Re: Motor mount is a 4 letter word
what's the 4 letter word? :p [LOL]
goodluck [ThumbsUp]
#49375 - 11/07/05 03:45 PM Re: Motor mount is a 4 letter word
TURD. I believe the correct phrase is, "Motor mount is a turd." I've broken a couple myself and wheel with others who've had this happen as well. Never replaced one myself, I brought mine to the shop for that. It can be done at home though, just look around "backyard mech", or "probs/annoys" if the dealership's not too kind this time around. [Smoking]
#49376 - 11/07/05 04:53 PM Re: Motor mount is a 4 letter word
It can be done on the trail with knats flying around in about 2 hours. Just ask Kevin & Troy.
#49377 - 11/07/05 05:03 PM Re: Motor mount is a 4 letter word
[Laughing]
I'm sure it's a good story [Smoking]
This'll get you off of the trail & back home too, if you aren't carrying a spare MM. -
#49378 - 11/07/05 05:53 PM Re: Motor mount is a 4 letter word
Someone needs to weld a cable to the top and bottom that only lets it move a little bit. Chain might work too, but steel cable seems like it would be best.
#49379 - 11/07/05 05:59 PM Re: Motor mount is a 4 letter word
We went over "limiting straps" ad nauseum here on XOC. I believe Ken ( [Wave] ) or 01SalsaX use them, and a cupla' others too. The mounts seem to be engineered to fail before anything worse does smile ..I'd like to sit in on the next MM install locally. Maybe do one for a mod day?
#49380 - 11/07/05 08:15 PM Re: Motor mount is a 4 letter word
01SalsaXterra Offline
Loc: Suffolk County,NY,USA
torque strap
It can be easily adapted for the xterra. Definitley will save some motor mounts.
Hey Dan! [Wave] (Dbax)
I got "IT" from ebay.
Now it burns when I pee..
#49381 - 11/07/05 08:32 PM Re: Motor mount is a 4 letter word
It really was not that bad.
Try to ignore the exteme heat around MOAB
Jack vehicle
Pull Drivers side tire
Drop front diff
Piss and moan about not having a universal
Cuss a few times
Swear at everyone driving by
Jack engine up
Swear at everyone driving by again
Pull MM
Put in new MM
Ignore freaking bugs
Cuss a few more times
Put it all back together
#49382 - 12/07/05 01:21 PM Re: Motor mount is a 4 letter word
bikesdestroy Offline
Loc: Colorado Springs
Can be done at home/ on the trail.
1. Lift and support the front end w/ jack stands
2. With engine cool, remove front skid and/ or any forward aftermarket skids.
3. Remove the wheel on the side that failed.
4. If you have some form of a 14mm socket or wrench that can get in there, then it will be easy. If not, then you need to drop the front end just a little.
5. There are 4 17mm bolts. Two in the front on the cross member, and two behind near the T-bars. We found 3 of the 4 bolts to be different lengths so mark and/or don't mix them. Support the front diff on your factory jack and then lower just enough to get your 14mm in there to the two lower motor mount bolts. Be sure to watch the CV boots as to not tear one.
6. The one upper motor mount bolt should pose no problem getting to.
7. If you are at home, use a hoist to lift the engine ~1 inch. This is enough to slide out the entire motor mount. If on the trail, use your buddy's stock jack to lift the engine from the bottom. **Remember that the other side is attached, so don't go further than you need!!**
8. Install the new motor mount, lower the engine and bolt up the motor mount tight. Don't forget to tighten any of these bolts! Lift the diff back up and reinstall the four bolts remembering which ones went to what. Attach wheel and skids and lower the truck.
9. All done. Should 1-1.5 hours at home with help. ~2+ on the trail with help.
Be carefull and good luck.
Troy
#49383 - 12/07/05 08:01 PM Re: Motor mount is a 4 letter word
Nissan is covering the MMs!!!
#49384 - 12/07/05 08:54 PM Re: Motor mount is a 4 letter word
Thats provided you still have a warranty. I'm at 93,000 miles...
#49385 - 13/07/05 12:37 PM Re: Motor mount is a 4 letter word
Update...
Service manager is fighting the claim. Donkey F***er. I am responding by citing the Magnuson-Moss Warrenty Act (Fed Law 15 U.S.C. 2302 9c)) We'll see where this leads now...
#49386 - 13/07/05 02:00 PM Re: Motor mount is a 4 letter word
buffalo Offline
Loc: los angeles, california
Hey Dave if you run out of luck at your dealership try foothill nissan in La Canada, they are offroad family or have been in the past, i satrted taking my truck there after Ivana recommended them. Good luck.
use the SEARCH function! Now you know... and knowing is half the battle!
#49387 - 14/07/05 02:29 PM Re: Motor mount is a 4 letter word
New update!!!
Nissan is going to cover the MM. The service manager, Joel at Valencia Nissan, went to bat (after learning about the Magnuson-Moss Warrenty Act?)and got it taken care of under warrenty. Joel rocks!!!
#49388 - 20/07/05 08:20 AM Re: Motor mount is a 4 letter word
[sarcasm]I'm cursious about something... since when did Nissan start putting so many motorsin the Xtera? I thought 99% of all automobiles had engines? Wouldn't that make it an engine mount?[/sarcasm]
#49389 - 20/07/05 08:23 AM Re: Motor mount is a 4 letter word
Dork.
#49390 - 20/07/05 02:54 PM Re: Motor mount is a 4 letter word
[b][sarcasm]I'm cursious about something... since when did Nissan start putting so many motorsin the Xtera? I thought 99% of all automobiles had engines? Wouldn't that make it an engine mount?[/sarcasm]
Dork.[/b]
eek you got that right!! laugh [LOL]
funny thing is EVERYONE called em motor mounts...
#49391 - 20/07/05 05:55 PM Re: Motor mount is a 4 letter word
Motor = Engine
Driveshaft = Propeller shaft
Whats the difference?
