Hey all! Maybe someone has had this problem and can help. My car died today on the highway. (Its an 02 XE, 4x4, v6, 5spd) I was cruising about 55-60 in 5th and it started to lose power. When i depressed the clutch, it slowley died. There was no miss, just the slow death. Kind of like when you pull the fuel pump fuse to get rid of the pressure and let the car run. I had the car towed home. I Tried to start it again and it cranked over and died. I tried again and it started. No problem. No miss, no hesitation. It reved up just fine. It ran for about 10 minutes and I shut it down. When I tried to start it up again, it cranked over, ran for a second and died. The rpm gradually fell, not the quick death kind like the distributor stopped or it lost spark, but the kind that makes me think it is not getting enough fuel.
Anyway, it would not start again for about 2 or 3 hours. Then I tried to start it again, and it turned right over and purred. Once again, no miss, no hesitation, and it rev'ed just fine.
Had anyone had this issue before? I think it is in the fuel system, but if someone has had this problem, that would narrow it down, rather than go through everything. Fuel pump? Fuel pressure regulator? Relay? Sending Unit? Fuel filter (fingers crossed, cheapest fix)?
Any input will be greatly appreciated.
THANK!
2002 Xterra XE
v6 - 4x4 - 5spd manual - BFG TA/KO
always dirty
