0 registered (), 170 Guests and 0 Spiders online.
#495290 - 15/03/10 02:04 PM Split boot?
jasonjrk Offline
Loc: St Louis, MO
I was in getting new tires and the mechanic noticed a damaged boot on the front axle. He said you'd have to replace the entire axle to repair it. What do any of you think about using a split boot instead?
2001 Xterra
#495296 - 15/03/10 07:52 PM Re: Split boot? [Re: jasonjrk]
vacsimile Offline
Loc: Middle of Nowhere
I've replaced many CV boots before without replacing the axle... I don't see why the X would be any different. Sometimes depending on the cost of the axle, it's worth the extra $ to just replace the whole thing... if you're doing the work yourself, that is (it can be a PITA and quite messy to replace just the boot).
The only thing I can prove is there is no proof.
#495297 - 15/03/10 08:45 PM Re: Split boot? [Re: vacsimile]
granitex Offline
Loc: Columbus. Oh
Step one, pull axle with split boot.
Step two, replace split boot with a new one
step three, replace axle.
If you have ever pulled an axle you can do a boot
#495304 - 16/03/10 07:13 PM Re: Split boot? [Re: granitex]
vacsimile Offline
That is a bit misleading... to replace the boot you'll have to disconnect the CV joint from the axle. Not sure about the X, but some are more complicated than others with circlips and spacers that have to go back in the right way.
#674123 - 19/12/10 07:59 PM Re: Split boot? [Re: jasonjrk]
ASTE25 Offline
Loc: New Market, Alabama
I don't like those split boots. I'd just get a remanufactured shaft instead. I've installed some of those split boots and they never seemed to last, the "glue" wouldnt hold well and they really didn't save that much time.
2011 S 4X4 Night Armor 6 speed
#674139 - 20/12/10 07:21 AM Re: Split boot? [Re: ASTE25]
granitex Offline
Loc: Columbus. Oh
The OP had a split on the boot, and was asking about replacing the boot without replacing the axle.
#674141 - 20/12/10 12:12 PM Re: Split boot? [Re: granitex]
ASTE25 Offline
I don't know, I read the last line of his post as asking what we think about using the boot with a split down the middle designed to be able to be put on without removing the axle. I may be wrong, but that's how I read it.
Edited by ASTE25 (20/12/10 12:13 PM)
#674142 - 20/12/10 12:55 PM Re: Split boot? [Re: ASTE25]
granitex Offline
Loc: Columbus. Oh
He did but the split boots to fix it are junk, Thats why you need to take the CV aprt to fix it. Unless you just replace the entire axle. Either way its an esy enough fix.
#674147 - 20/12/10 09:57 PM Re: Split boot? [Re: granitex]
ASTE25 Offline
That's basicly what I said.
