#49744 - 04/11/06 05:14 PM Drive shaft play
i got under my X today for inspection. Is it ok that i can turn my drive shaft about a 1/4" back and forth? Is it suppose to have a little play in it like that?
#49745 - 04/11/06 06:48 PM Re: Drive shaft play
No, where is the play coming from?
#49746 - 04/11/06 07:30 PM Re: Drive shaft play
Does it slide front to back or does it rotate a 1/4" ??
#49747 - 05/11/06 12:23 AM Re: Drive shaft play
Hmmm. I have noticed a little bit of play in mine as well, while trying to rotate it. I figured it was normal.
So there isn't supposed to ANY play when the drive shaft is rotated?
#49748 - 05/11/06 05:42 AM Re: Drive shaft play
I don't think it should have any. I just went and checked both of mine and they don't move at all.
Service manual says: Journal axial play 0.02mm (0.0008") or less.
#49749 - 05/11/06 07:09 AM Re: Drive shaft play
You need to determine where the movement is coming from. There will be some play in the differential. I think the measurement given is for the slip joint which may have a little movement allowed but there should be none detectable at the U/Js.
#49750 - 05/11/06 07:18 AM Re: Drive shaft play
ChuckH Offline
He said "turn" so I assume that means rotate. If so, then some movement is normal.
#49751 - 05/11/06 09:53 PM Re: Drive shaft play
That's what I figured.
#49752 - 06/11/06 05:54 PM Re: Drive shaft play
My 06 OR auto has a lot of rotational driveshaft play which appears to be "ring and pinion play". Because of that I get a pretty good "clunk" when shifting into reverse and also when driving along at 30 mph I'm aware of a mild clunk if I abruptly take my foot on and off the gas pedal. I can also here it clunk twice at 5-15 mph as the transmission is downshifting as I come up to stop sign. If the radio is on I can't here the clunks. I have about 17M miles on the vehicle. I'm reluctant to have the dealer mess with it unless someone thinks its a problem.
#49753 - 07/11/06 03:14 AM Re: Drive shaft play
marmillerX Offline
Loc: Shrewsbury, MA
I had the same issue on my rear drive and it turned out to be a busted U-joint. Do you feel vibrations at speeds over 40mph? I got a replacement one with a zerk fitting.
#49754 - 07/11/06 01:13 PM Re: Drive shaft play
yeah it moves when i rotate it not back and forth in the splines. So it is normal to have some play in the driveshaft?
#49755 - 07/11/06 02:52 PM Re: Drive shaft play
Kaiser Offline
It's hard to tell by what you are saying if what you're experiencing is normal or not... but it certainly wouldn't be a bad idea to slap in some new U joints.
#49756 - 07/11/06 03:04 PM Re: Drive shaft play
what im saying is that i can turn it back and forth just a tad..its not loose at the ujoints and it doesnt slide back and forth. It just turns a little when i grab it.
#49757 - 07/11/06 03:28 PM Re: Drive shaft play
I already posted this: Service manual says: Journal axial play 0.02mm (0.0008") or less. Measure the rotation, there should not be much. The ring an pinion should not have that much play.
#49758 - 07/11/06 06:54 PM Re: Drive shaft play
on my truck, when im driving and let off the gas, it kinda feels like it.....hard to explain. it kinda kicks and seems to bog down a good bit. when i put my foot back on the gas, it clunks and goes. i'll check out the u/j. are they hard to replace? its been doing this since i got the truck. its had me worried figureing it was the tranny since ive had so much bad luck with them. also, where can i find said u/j in the event of replacement?
#49759 - 18/03/07 05:48 PM Re: Drive shaft play
Ok way back in Nov it was asked where you got that u-joint with a zerk fitting. It still need to be answered. I need one before thursday. HELP!!!!
#49760 - 18/03/07 07:02 PM Re: Drive shaft play
01SalsaXterra Offline
Loc: Suffolk County,NY,USA
4x4parts.com has u-joint replacements.
There are TWO per driveshaft.
I will be replacing all of mine shortly.
I got "IT" from ebay.
Now it burns when I pee..
