214
#500263 - 17/01/02 09:29 PM
PowerTank Co2
Loc: Tacoma
Does anyone have one? If you do how do you have it mounted in you Xterra? Pictures would be great too!
-Rick
-Rick
#500264 - 18/01/02 10:41 AM
Re: PowerTank Co2
Originally posted by rrdstarr: Does anyone have one? If you do how do you have it mounted in you Xterra? Pictures would be great too!
-Rick Yep. Not an actual Powertank, I had it put together cheaper than a Powertank. I did buy the 25 ft. Powertank air hose though, and it is really well made. I have it sitting in the cargo area of my truck standing up in a milk crate with my winch accessory kit and a bunch of other shit. ![laugh laugh](/forums/images/graemlins/default/laugh.gif) [ 01-18-2002: Message edited by: Philosopher ]
#500265 - 18/01/02 02:16 PM
Re: PowerTank Co2
Loc: Tacoma
The easy way!
Thanks Mike!
-Rick
#500266 - 18/01/02 04:18 PM
Re: PowerTank Co2
Loc: Oak Ridge, NJ
You can buy a fire extinguisher mount for the CO2 tank as well, but like Mike I usually carry mine in a milk crate when wheeling with other recovery equipment.
#500267 - 18/01/02 04:29 PM
Re: PowerTank Co2
Loc: Tacoma
I just filled my 10 lb. tank and it was $16.70. I adjusted the regulator down to 90 psi and zipped on and off some lugnuts for fun! Sure is convienent!
-Rick
#500268 - 18/01/02 09:56 PM
Re: PowerTank Co2
Loc: Phoenix, AZ
I built my own CO2 setup and am in the process of building a standup mount for in the cargo area. Already have the wingnut clamp that goes around the tank, so I just need to fab the bracket that will bolt to where one of the tie downs go.
#500269 - 18/01/02 10:17 PM
Re: PowerTank Co2
Loc: Tacoma
Keep me updated Craig! I'd like to place my Powertank bracket, somewhere, in back and have some hardlines run for lockers when they go in.
-Rick
#500270 - 19/01/02 10:26 AM
Re: PowerTank Co2
Loc: Portland, OR
FYI: The people that make homemade CO2 setups need to make sure they purchase a regulator that can handle the extreme freezing temps of the CO2.
confused previous X owner/then a previous Rover owner/ back to an X owner 07 Avalanche OR X 4x4
#500271 - 19/01/02 10:48 AM
Re: PowerTank Co2
Loc: Sugar Land, TX
Forgive my ignorance, but what is a Powertank and what does it do? Do you use it to power air lockers, air tools, ect?
#500272 - 19/01/02 12:00 PM
Re: PowerTank Co2
Loc: Tacoma
Pino...yes to all your questions! http://www.powertank.com Mosi! Shshhhhhhhhhh! Don't tell anyone I got a Powertank! I'll fill up your Disco next time we are out!
-Rick
#500273 - 19/01/02 12:01 PM
Re: PowerTank Co2
Loc: Portland, OR
Originally posted by rrdstarr: Pino...yes to all your questions! http://www.powertank.com
Mosi! Shshhhhhhhhhh! Don't tell anyone I got a Powertank! I'll fill up your Disco next time we are out!Rick... shhhhh.. I've got one too ![laugh laugh](/forums/images/graemlins/default/laugh.gif)
#500275 - 19/01/02 12:31 PM
Re: PowerTank Co2
Loc: Tacoma
Problem is Ian that it has to be upright to work correctly. I mean you could carry it up there I suppose then take it down when you need it? ![smile smile](/forums/images/graemlins/default/smile.gif) Mosi? what size did you get? I got the 10 lber. ![laugh laugh](/forums/images/graemlins/default/laugh.gif)
-Rick
#500276 - 19/01/02 12:42 PM
Re: PowerTank Co2
Loc: Portland, OR
I got the 10 lber too.. I used it last weekend and it's amazing how fast it will air you up! I am not to fond of putting holes in the truck for mounting the bracket, so I am utilizing the 2 tie downs that are closest to the back seat. I ran a ratchet strap through the bracket and it's nice and tight. I only want to carry it with me when I wheel so it works out perfectly.
#500277 - 19/01/02 12:50 PM
Re: PowerTank Co2
Loc: Tacoma
I think I might do the Mr T method and carry it in a milk crate! Only need it when I am wheeling too!
How did the Sliderz go on the Disco that weekend? Never did here back from you if you wanted my help?
-Rick
#500278 - 19/01/02 01:06 PM
Re: PowerTank Co2
Loc: Portland, OR
The install went fine but took a while since we drilled 24 holes (total). Installed the gas tank skid and installed the new coil springs all the way around.
#500279 - 28/01/02 02:39 PM
Re: PowerTank Co2
Originally posted by rrdstarr: I just filled my 10 lb. tank and it was $16.70. I adjusted the regulator down to 90 psi and zipped on and off some lugnuts for fun! Sure is convienent! That's what I used to pay here close to DC. Now that I've moved out to the sticks, I can get it filled for $10.36 @ the local welding shop. ![wink wink](/forums/images/graemlins/default/wink.gif)
#500280 - 28/01/02 07:32 PM
Re: PowerTank Co2
Loc: Tacoma
Thanks T! I just found the three closest places to my house. with Tax and some sort of HazMat fee that was the cheapest.
-Rick
#500281 - 29/01/02 09:11 AM
Re: PowerTank Co2
Originally posted by rrdstarr: Thanks T! I just found the three closest places to my house. with Tax and some sort of HazMat fee that was the cheapest. Right on - also try places that fill up fire extinguishers, sometimes they're a bit cheaper ...
#500282 - 29/01/02 10:50 AM
Re: PowerTank Co2
Loc: Aliso Viejo, Ca,
Ok-What parts and tools are needed to make one of these. Any C02 tank? How about a used diving tank?
#500283 - 29/01/02 06:17 PM
Re: PowerTank Co2
Loc: Beaverton Oregon
Building your own? Look here: Beverage factory
#500284 - 29/01/02 06:21 PM
Re: PowerTank Co2
Loc: Tacoma
Dick, if you could would you forwrd to me what bookmarks you have about CO2 and onboard air!
Your red-headed step son!
-Rick
#500285 - 30/01/02 11:40 AM
Re: PowerTank Co2
So-as far as parts go- 1-CO2 tank 1-Regulator 1-hose and you have a power tank?
#500286 - 30/01/02 02:30 PM
Re: PowerTank Co2
Loc: Tacoma
Basically that is it! Just make sure you get a "Good" high pressure regulator! Most of the ones I have seen only got oto 60psi. The Powertank one goes to 160psi! You need 70 Psi to run ARB lockers and 90psi to run most airtools.
I am still thinking how I want to plumb this? Front and rear air hookups and ARB front and rear lockers is my ultimate goal.
-Rick
#500287 - 30/01/02 02:50 PM
Re: PowerTank Co2
I just want to be able to air up my tires. I'm no worried about are tools, I don't have any. Same w/ lockers. I figure that any thing is better that the $20 air pump from wallmart.
This seems do-able. For the cost. On the 10lb tank, anyidea how many tires that would be.
