Just wanted to let you know that I installed a locking handle on my roof bin from Southco (the manufacturer of the stock handle) The part # to order is 92-41-521
Clicky You can contact Southco at info@southco.com to find a supplier near you. The install took under 10 minutes, and the only part you use from the new locking handle is the handle itself, all of the original parts are re-used. Here is a quick install explaination:
1. Remove the first nut and lock washer holding the locking mechanism in and set parts to side (note how they go back together).
2. Remove the two small screws holding the handle onto the bin.
3. Pull the handle out of the bin
4. Remove second nut and spacer.
5. Remove third nut and lock washer, and pull housing off of handle.
6. Pull locking pin out of handle and set threaded bolt aside.
7. Disassemble new handle the same way you did the stock handle.
8. Re-assemble new locking handle using all the parts from stock handle, including the shorter bolt removed earlier (This is needed due to the original bolt being smaller and all original parts look to be stainless steel).
9. Re-install new handle the same way it was un-installed, also using the black gasket that was on the original handle.
You should now be done and have a new locking handle.
