0 registered (), 227 Guests and 0 Spiders online.
#511987 - 14/08/06 10:05 PM first dyno pull on a stock 05 offroad @4200 feet msl
just unstraped my 05 off road from a all wheel drive mustang dyno (only made pulls in rear wheel drive) to get a base line before the ecu and intake, headers, and cat back exhaust goes on.
made 230.8 hp @ 5700 rpm and 238.9 ft/lbs. @ 3700
not bad for a dyno run above 4000 feet with 90 degree outside temp!
will keep you posted on hp. numbers as the mods go on!
#511988 - 15/08/06 05:53 AM Re: first dyno pull on a stock 05 offroad @4200 feet msl
Manual or auto?
#511989 - 15/08/06 06:42 AM Re: first dyno pull on a stock 05 offroad @4200 feet msl
GrayHam Offline
Are you working with the folks at COBB?
I saw the thread in the Utah Xterra Club forum. I was wondering if yours was the Xterra they're researching through . . .
#511990 - 15/08/06 10:07 AM Re: first dyno pull on a stock 05 offroad @4200 feet msl
They have an ecu out????
#511991 - 15/08/06 11:21 AM Re: first dyno pull on a stock 05 offroad @4200 feet msl
its a 05 off road 5 speed auto so there is some loss through the converter. the manual should put down a few more ponies.
cobb had put a thread up on one of the forums looking to do an ecu tune and i am building this xterra for a new magazine called tpr trucks that will launch with a feature on the xterra fourth quarter of this year hopefully so this is the launch issue feature vehicle.
they are in the process of looking into the nissan market. that's all they said on their thread as a request.
i am ordering the nismo headers and cold air intake as well as looking at various cat back exhausts and that was the primary goal of getting a baseline run done. i have talked to them about what if any changes need to be done to the xterra motor to accomidate the increase in breathing at both ends of the motor as far as ecu adjustments go but that's it thus far.
#511992 - 15/08/06 03:10 PM Re: first dyno pull on a stock 05 offroad @4200 feet msl
On a mustang dyno those are fantastic numbers (if they put in the corret parameters; IE vehicle weight) on a mustang a 6spd 287 bhp 350Z generally only pulls 210-220
Considering the X uses essentially the same motor as the Z and most other nissan cars, I can say N/A modding is a complete waste of $ and effort. A few ponies isn't worth the investment. To unleash the pontential of the VQ, you need FI; more specifically turbos.
Click here to see Video
Breathing mods like intake and exhaust will net you maybe 10-15 whp. For the investment, it doesn't seem worth it
#511993 - 15/08/06 03:38 PM Re: first dyno pull on a stock 05 offroad @4200 feet msl
will scan and post dyno print out
it had a totally flat torque curve too really flat!
vehicle weight was set at 4750
