221
#51365 - 19/05/05 07:15 PM
Re: Winch Bumper Pictures
That second pic is especially nice...
#51366 - 19/05/05 09:18 PM
Originally posted by Daggerdoggie: Originally posted by PHXX: [b]Wow.... By painting your Shrockworks bumper Yellow, makes it the bumper look totally different! Interesting touch with the blue paint.. anymore pics of ur truck? A couple: [/b]Very Nice! Is that the TJM snorkle? It looks reallly short as far as how far it goes up the window pillar.
#51367 - 19/05/05 10:04 PM
WOW!.... I mean WOW Niiiiccccceee!
#51368 - 20/05/05 02:55 AM
Originally posted by PHXX: Originally posted by Daggerdoggie: [b] Originally posted by PHXX: [b]Wow.... By painting your Shrockworks bumper Yellow, makes it the bumper look totally different! Interesting touch with the blue paint.. anymore pics of ur truck? A couple: [/b] Very Nice! Is that the TJM snorkle? It looks reallly short as far as how far it goes up the window pillar.[/b]It's a TJM. It is shorter up the "A" pillar and goes inside the fender, not all the way to the end like the ARB. Mike, did you take that shot?
#51370 - 20/05/05 01:17 PM
I'm sure Calmini can get away with more/last longer in areas w/o excessive salt...in NJ though, my Shrockworks powder coat and my Skid Row Powder Coat last fine, the Calmini stuff falls off. At least the shackle tabs don't rip out of the bumper like they do on ARB's.
#51371 - 20/05/05 01:40 PM
You mean the Hi-lift jack point? I dont know why people think those are shackle mounts, they were designed to be a point to where the hi-lift could jack the front end up with the optional accessory.....
Sure it looks cool to have shackles on there, but thats *not* what its there for...
#51372 - 20/05/05 02:31 PM
Yeah - I get it, its like those "Sport Bars" that look like they're supposed to be Roll Bars... Here's the ARB website showing the way to hook up that spiffy Hi-lift Jack Point too....very clear it has nothing to do with winch hooks or shackles and such.
#51373 - 20/05/05 03:11 PM
The paint on my calmini bumper is showing lots of rust bubbles and has already started to flake off some paint and its only 8 months old. The calmini sliders which are a year old are having some rust isssues away from the scratches. Right side is starting to flake large sections off while the left is about to start as the rust is visible under the paint. I'm planning on having them both sand blasted and will repaint them this summer. ND is a non salting state thank god.
#51374 - 20/05/05 03:21 PM
I just paint the Calmini stuff black after letting the original paint flake off...its not like the metal isn't OK at least.
#51375 - 20/05/05 04:51 PM
Originally posted by Grand Forks Xterra: The paint on my calmini bumper is showing lots of rust bubbles and has already started to flake off some paint and its only 8 months old. Is it flaking just in the center tray area or all over? Mine was only coming off in the center. It appeared on mine that the center area was a different grade of steel more susceptible to corrosion than the rest.
#51376 - 21/05/05 12:07 PM
If I had to guess, it looks like Calmini's prep of the metal needs work before painting....when you have delamination like that, it usually means the paint didn't bond to the metal....and that's typically because the metal had a film of something on it that kept the paint from getting a good grip on the metal surface. The SLR stuff, the Shrock stuff, the Skid Row Stuff is exposed to the same salt and abuse that my Calmini stuff is....but the Calmini stuff is the ONLY stuff loosing its paint. I like generally Calmini from an engineering standpoint, but their painting sucks big hairy moose cock.
#51377 - 21/05/05 12:07 PM
It is flaking in the center section. Rust bubbles are forming all over the rest of it though.
#51378 - 21/05/05 01:07 PM
That's why I live in Good Old Rust-Free Arizona!
#51379 - 21/05/05 03:07 PM
Originally posted by TJ: I'm sure Calmini can get away with more/last longer in areas w/o excessive salt...in NJ though, my Shrockworks powder coat and my Skid Row Powder Coat last fine, the Calmini stuff falls off.
Why would you even use those tabs to recover in the first place. We have perfectly good tow hooks mounted to the frame. And btw having a winch hook attached to one of those hi lift points doesn't make it a recovery point. Even on the shrock there's no need to risk possibly tweaking the bumper when you can just hook up to a 10 dollar tow hook
