Ok so like i stated earlier i had wanted this, was told i couldnt get it or have it installed,went and did it myself.It cost $256.99 with shipping (FEDEX)and trim piece included. Email Rob Farrell at info@brand-new.us . Got the idea from this guy
http://www.reverendbiker.com/ Pretty simple steps. In addition to what comes in your box, grab some more zip ties if you want a cleaner install. Youll need a little waterproof grease to run around the seal for the temp sensor. And a torx bit to fit the new mirrors screw. they said #120 i used a #25 and tightened it hand tight. popping off panels can be unnerving but the pop is just the panel detaching.I hate reprogramming stations and didnt want to have to redo a blinking airbag light, i left the battery connected. also to verify everything with my multimeter.
1. remove the old mirror. youll need a thin,long flat hear screwdriver or equivalent. it will slide between the mirror and the glass mount(red arrow) to push up on the locking tang(green arrow)Rock back and forth, voila.
![](http://img455.imageshack.us/img455/9931/gentexmirror0091fb.jpg)
2.pull the panels. unscrew the handle with a #3 cross tip. Pop up and out the upper panel. Next the small panel just under the upper one. then the door sill panel. now pull the black plastic piece holding the kickpanel to the carpet in the front of the foot well. removed the kickpanel and then the reinforced panel behind it. place these nicely somewhere where they wont get damaged. Note you will have to work the weatherstipping on the door frame off the panels as they sit under it on the outer side. itll look something like this.
![](http://img455.imageshack.us/img455/6137/gentexmirror0088ev.jpg)
3. run the temp sensor. i didnt want the sensor exposed like ive seen on other set ups. i wanted to keep it away from direct wind and radiator heat.start applying a small amount of grease to the seal on the sensor, next open the hood and drop it down right behind the light assembly. under the X you will see the front left body mount it should attach to that.there is a small hole you can put it in.(red arrow). Zip tie it a coulple inches back to the mount. so you can remove it if need be later and to secure it better. for reference, the green dot is the underside of the front bumper.
![](http://img455.imageshack.us/img455/3198/gentexmirror0064re.jpg)
4. now run the covered wiring along the driver side of the engine bay, zip tie it to the existing harness that runs under the airbox inlet.(red arrow shows the harness for the sensor)
![](http://img352.imageshack.us/img352/1118/gentexmirror0025xg.jpg)
