321
#55620 - 05/05/02 11:54 AM
Re: New Product: Xterra Soft Roof Rack
Loc: Phoenix, AZ
I would be very interested in the interior rack.
#55621 - 05/05/02 02:03 PM
Loc: Andes, NY
I would be even more interested in the interior rack.
Boldly going nowhere.
#55623 - 05/05/02 02:17 PM
Interior! Interior! Interior! (just thought I'd jump on the bandwagon, here).
I can see the use for the one up top, and since Graham has my safari rack and isn't considering handing it back anytime soon (I know, I know... I gave it to you), it might be interesting, but I'd much prefer seeing more about the interior one.
Whatevs.
#55624 - 05/05/02 05:27 PM
Hmm. I think the interior looks neat!
#55627 - 05/05/02 06:10 PM
Loc: Virginia
i think the rack belongs on the 2003 model, it would go well w/the leather seat option.
"the future is no place to place your better days" Dave Matthews
#55628 - 05/05/02 06:29 PM
I disagree with Rob's post.
I would NEVER worry about that webbing failing at any time.
We use webbing (albeit, most likely stronger) for our skydiving rigs. This is something we totally trust our lives in. We trust it so much that it's pretty much not even a worry.
We use webbing half as wide as that to connect the rigs to the canopies. I can't even begin to describe the forces that webbing goes under as the canopy opens and stops us from 130mph to 10mph.
Although, the webbing would be exposed very long term to all kinds of harsh enviroments. I wonder how much months of intense heat, heavy snow, or rain would harm the webbing?
There's a lot of things to factor in. But I would not worry about the webbing failing under any load. Unless it is a low quality webbing, or low quality connectors, or low quality craftmanship.
But its all good points.
Does anyone that is familiar with this compnay know the quality of their products?
I'm also going to do some research on the type of webbing used in skydiving rigs.
Anyways
Oh yeh, I can't wait for the interior webbing!!
#55629 - 05/05/02 07:21 PM
Loc: longview texas
rack looks cool but how will the nylon hold up under the sun
#55631 - 05/05/02 08:21 PM
Originally posted by Rob: The attachment mechanics are far too complex. What are there, 20 buckles to work with there? You say that the attachment is likely to change, that's good, those friction clasps don't really supply much in the way of security.
Which is why it will change, to deter theft. The front and back ends will be loops. The crossbars will be removed, and the loops slid over them, then reattached. The crossbar is then adjusted to tighten the webbing. Long term resistance to stretching and fade will be an issue, as well as stretching when wet. Again, this product is a prototype, and I am simply gathering information for Raingler. Thank you so far for everyones contributions and thoughts. The interior web will have fewer issues against wear and tear, and be easy to install and adjust.
#55632 - 06/05/02 05:02 AM
Loc: Brooklyn, NY
Ian , if you put a tire up there will it bouce up and down on bumps?
or the web is prety much tight that it will not move up and down ?
#55633 - 06/05/02 05:31 AM
Loc: MN
Originally posted by xoc: Originally posted by nimbus 2001: [b]What is the load capacity? What would the length be (How far can you spread the crossbars)? The load capacity should exceed the load capacity of the stock rack (which is 125 lbs.).
The cross bar racks are as far apart as they will go in the picture.[/b]My concern is that people would put somthing heavy on it and the rack would fail (perhaps right away)..My reason... instead of putting weight on the rack in a downward fashion you are loading it horizontally. I don't think that they planed having it loaded that way. Just something to think about
#55635 - 06/05/02 07:01 AM
Loc: Oak Ridge, NJ
Originally posted by xoc: [QB].
This rack is designed with dry bags, and camping gear in mind, not really a spare tire, Hi-Lift or other very heavy items, although it should support them.
QB] For the price this looks like a good add on for those that have a height restriction because of a garage. Like you said throwing your camping gear and such up there and having many lashing points is much better than laying it between the rails on the paint. I would be interested in the interior one.
#55636 - 06/05/02 07:54 AM
Loc: Huntington, NY
Originally posted by xoc: It can hold anything a huge Yakima LoadWarrior can hold, but doesn't stick up a foot above the truck or look unsightly. Err, no. My rack does NOT stick a foot up off the factory rack - that's just ridiculous. It also looks a LOT better (smoother, cleaner) than this thing. Good God. With a real rack, the weight is carried DOWN, onto the supports of the roof rack. With this thing, the weight is carried LATERALLY, being held by the two crossbars in the front/back, which is basically four screws in plastic. The sides are held on better, of course - but again, it's a lateral support of the weight. I don't know that the roof rack supports like that - they weren't designed for that. As others have mentioned also, there are far too many failure points - rings, buckles, seams... This thing will probably stretch and flap in the wind and all kinds of stuff. Is the hardware stainless? Or will it rust all over your paint job below? I agree with FSRBIKER in that this might be a good option for those with clearance issues with their garage or something, but seriosuly... Get a REAL rack. ![[Finger]](graemlins/thefinger.gif)
#55637 - 06/05/02 08:36 AM
Loc: West Orange, NJ
What uses do you guys want the interior rack for? As a pet divider, to hold things down?
#55638 - 06/05/02 08:46 AM
Loc: Huntington, NY
Originally posted by hmacmill: What uses do you guys want the interior rack for? As a pet divider, to hold things down? To store stuff normally kept on the floor of the cargo area... Tools, blankets, jumper cables, whatever... It's just a way to use normally unused space in the truck, and open up more room down below for other stuff.
#55639 - 06/05/02 09:44 AM
[/QUOTE]To store stuff normally kept on the floor of the cargo area... Tools, blankets, jumper cables, whatever...
It's just a way to use normally unused space in the truck, and open up more room down below for other stuff.[/QB][/QUOTE]
so you're talking about a vertical rack?
#55640 - 06/05/02 11:30 AM
Loc: Burbank, SoCal
I hardly ever load the top, so I don't think I will use it..But it looks cool, I would buy it just because it looks cool.. when does it come out? Huevos
01' with JWT POP charger
#55641 - 06/05/02 11:50 AM
Loc: Kearney, MO
Just having the ability to load the tent, chairs, sleeping bags, etc. onto the roof rack without body contact would be great. I am one of those with a severe truck height issue, as it stands I only have approx. 1" available before I would rub the rails backing into the garage.
I would be interested in both.
Fletch "We Know Who You Are... Bronze"
#55642 - 06/05/02 12:14 PM
Loc: Huntington, NY
Originally posted by hmacmill: so you're talking about a vertical rack? No, horizontal... The net would be a few inches underneath the ceiling, and you can stuff things up in there...
#55643 - 06/05/02 02:14 PM
So far the only items of note I've put on top of my X are a new queen mattress and box spring and my spare. The mattress set is moot here, and I put my spare directly on the roof between the crossbars (on top of the Nissan rubber strips you can buy for $18) and it suits me fine. Most anything else will be fine the same way, and if it's not "flat" I can just get a piece of plywood to rest on the rubber strips and then stack from there.
The interior setup might be handy though, Brent
