0 registered (), 50 Guests and 0 Spiders online.
#573044 - 28/05/10 03:10 PM Cruise Control Issues
Yetti Man Offline
Loc: Texas
The cruise on my 2001 X has not been working lately.
I turn the cruise "ON" and the cruise light comes on, but when I try to set at speed, the set light will not come on and the cruise control will not set speed.
I have taken it to multiple Dealerships with little to no information given to me. The first didn't even try to work on it saying that it was an electrical malfunction. The second did the same thing but offered me a ~$100 In-Depth Wiring Inspection(or something) which I declined.
I have checked the fuses and relays and haven't found anything pertaining to the cruise that has been burnt out.
Any thoughts on this issue? Feel free to ask questions. My explanation probably wasn't too informative.
#573094 - 01/06/10 10:52 PM Re: Cruise Control Issues [Re: Yetti Man]
Yetti Man Offline
Loc: Texas
Bump!
#573098 - 02/06/10 08:50 AM Re: Cruise Control Issues [Re: Yetti Man]
Gonzo-2 Offline
Loc: Lansing, Michigan
Cyclemut would be the guy to ask. My question to him would is if it possible you could have lost the sensor? This sounds like it has nothing to read to set the speed to. Everything works, but it can't set the speed to zero!
Just a thought...
-G
'03SE
BFG AT/KO
Pre-crash post count - ~1100
#573165 - 05/06/10 09:19 PM Re: Cruise Control Issues [Re: Gonzo-2]
FoxFive0 Offline
Loc: PNW, WA
It could be the wire itself grab an multimeter and get to work on checking the wires for grounds or shorts as well.
“Every good citizen makes his country's honor his own, and cherishes it not only as precious but as sacred. He is willing to risk his life in its defence and is conscious that he gains protection while he gives it.”
Mobile Elec Cert Pro Silver Level
#680435 - 25/08/13 07:53 AM Re: Cruise Control Issues [Re: Yetti Man]
5769 Offline
I had the same issue and found that my problem was the plastic button on the brake pedal was broken. It is the cruise cut off switch that turns the cruise off when you apply the brakes. There are 2 buttons one for the brake light and one for the cruise control. A $3.00 part at the dealer. Easy fix.
#680441 - 26/08/13 06:08 PM Re: Cruise Control Issues [Re: 5769]
Gonzo-2 Offline
"Bring out your dead! Bring out your dead!"
I appreciate you trying to help the guy, but really? Do think you may be a bit late to the dance on this one?
'03SE
BFG AT/KO
#682942 - 15/11/15 06:03 PM Re: Cruise Control Issues [Re: 5769]
Bogdan Offline
Loc: PHOENIX, ARIZONA
Well, I'd like if you could describe the plastic button or a pic of it.
I've found a gray plastic button on the floor and my CC does not set the speed while driving....of course over 25 mph...
