306
#58396 - 15/05/02 11:42 AM
Re: UB Skidderz now available for the Xterra
Loc: san jose, CA, USA
Originally posted by OffroadX: A spring-over would add about 6" to the height of the rear end. There is currently no way to make up for it at the front end short of a solid axle swap.
Brent How does the frontier do it? Does it use a flatter springpack? Could the X use that springpack if it does? Don't really know what I'm talking about here -- just thinking out loud.
#58397 - 15/05/02 01:53 PM
Probably a flatter spring pack, and the front spring hanger is tucked up higher and further to the rear on the curve of the frame rail instead of right at the bottom/beginning of the curve.
#58398 - 15/05/02 03:40 PM
Loc: Fredericksburg, VA
Originally posted by New Guy: How bout making a spring over kit and get the lift, remove them springs from that stupid place (I got stuck in snow last Sat. from those springs!) and rid the axle of all compromised equipment. ! Start the process of making the X a real off road vehicle.
my .02 Well get on it... and let us know how it turns out. Honestly, I prefer the spring under with these spring skids. A spring over leaves your axle fully exposed to bind up on rocks. With these and a good diff skid, you'll slide over them rather than potentially get hung up on the axle.
#58399 - 16/05/02 07:04 PM
Quick lesson learned...
When you install the bolt that mounts the shock to the skidder... use loctite. Found out the hard way today.
#58402 - 19/05/02 04:44 PM
Yep, that was something that came out in testing. The first set he sent me had a stud design (with a good nylon nut). This "second" set has a bolt design with course threads that threads into a nut that's welded into the UB Skidder.. and it worked it's way loose over the course of a few weeks.
Put it back in with some locktite and off I went.
The intent of switching was to reduce the amount of exposure. Those end threads are exposed a bit by a "post" type design, but switching the design around introduces more potential for harm than good.
I just came back from two days on the beach at OBX III and it has yet to work loose.
"Bad bad design..." I wouldn't go that far, because it's already been fixed. The production model will switch the design back the way it was previously.
#58403 - 20/05/02 12:50 AM
BP, you are right. There's no way the U-bolts could come down straight without either removing the plates that go over the top of the axle or replacing them with some that are wider. The shape of the Skidderz plates moves the U-bolts out farther, but the top palte won't allow that. That's why they come down at an angle. I would think they would develop some proper top lates to fix this problem. I don't know what the effect of slanted U-Bolts may be.
#58407 - 20/05/02 05:18 AM
And Joe somehow thought this would work ? Is it a real weld nut, or just some nut from Lowe's hardware that he welded on ?
I thought he was an engineer or something.... I'll check ont he weld nut vs a Lowes nut. He has a fabrication shop do all the welding, he just drills, specs, and finishes the end result. I assume they are using real weld nuts. No, Joe is not an engineer. He is a telecomm specialist in the Air Force for his day job. I didn't know you had to be... Are Steve and Spencer engineers? Oh, I'm a mechanical engineer, but I can't build parts for shit, but i CAN recognize a good design.
Originally posted by ChuckH: BP, you are right. There's no way the U-bolts could come down straight without either removing the plates that go over the top of the axle or replacing them with some that are wider. The shape of the Skidderz plates moves the U-bolts out farther, but the top plate won't allow that. That's why they come down at an angle. I would think they would develop some proper top lates to fix this problem. I don't know what the effect of slanted U-Bolts may be. The U-bolts aren't slanted. Not sure what those flimsy plates do that sit on top of the axle, but you remove em when you put these on. The Skidder does move the U-bolts out wider, but there is no need to replace those plates. If you'll closely inspect your rear end you'll notice there is a weld that moves along the horizontal plane. This weld has been ground down where the OEM u-bolts cross this plane. Since the new U-bolts are now sit at a wider stance, they don't have this. Getting the new U-bolts where they need to be takes a tap or two with a hammer to get them to even out align correctly), but it's not a show stopper by any means.
BTW the new U-bolts are 9/16in thick in diameter. That's about the size of the base of your index finger. I'd like to see you fail those.
Originally posted by xoc: One more thing, anyone thinking of buying these should check out Darlington's [b]Statement of Non-Liability. They are for off road use only, and if they break, it will be the result of your own decision to use them. He disclaims all responsibility for failure. Sounds like he really stands behind his products... ![[Freak]](graemlins/freak.gif) [/b] And Joe will stand behind his products. Every aftermaket vendor has a disclaimer similar to this one. That's to protect you from being sued when you, the idiot driver, drive your truck off a cliff and then want to come back and sue the vendor for your poor decision. The americal legal system has forced this into existence everywhere. Gimme a break.
Here's Calmini\'s
Ian, I appluad your skepticism, but why are you trying to kill these? Pointing out design flaws is great because that equals better safer products, but slamming a company (or individual for that matter) you've never dealt with I find silly.
Every design issue you've had beef with (only one) has already been corrected. What more do you want... A free set to "review" ? Take that up with Joe.
If you don't like them, or don't won't to deal with Joe, don't buy them.
Bottom Line guys, if you are interested in these, don't just take my word for it, call Joe and express your concerns. He really is a super cool guy to deal with.
joe@darlington-offroad.com Darlington Off-Road Products 592 N.6th E. St. Mountain Home, Idaho, 83647, US phone: 208-587-3922 fax: 786-551-2803
#58410 - 20/05/02 06:28 AM
Loc: MN
"Feel free to post any questions, concerns, bitches, gripes, complaints... etc."
You did ask for it though...
#58411 - 20/05/02 07:33 AM
If you remove the top plate and move the U-Bolts apart at the top too, then you have even less lateral support for the spring pack, which means that tiny bolt down the middle of the pack is taking all the lateral load. And that bolt is hanging out the bottom where it can get sheared off. The plates should have lateral spring support all the way up to the axle and that center bolt should have protection. All they'd have to do is run the steel up different lengths for different applications or have fittings to go over the U-Bolts so they are not out away from the leaf packs.
I very much like the idea, but I see some possible failure points that would really concern me. At the very least, I would carry my old stock plates, U-Bolts, and a couple new leaf pack center bolts with me when offroading.
#58412 - 20/05/02 08:19 AM
FWIW, the so-called "vertical" that BP drew isn't perpendicular to the axle tube. That doesn't mean the u-bolts aren't a little skewed, but not as far as the lines he drew would indicate.
#58413 - 20/05/02 02:20 PM
Originally posted by ChuckH: If you remove the top plate and move the U-Bolts apart at the top too, then you have even less lateral support for the spring pack, which means that tiny bolt down the middle of the pack is taking all the lateral load. And that bolt is hanging out the bottom where it can get sheared off. The plates should have lateral spring support all the way up to the axle and that center bolt should have protection. All they'd have to do is run the steel up different lengths for different applications or have fittings to go over the U-Bolts so they are not out away from the leaf packs.
I very much like the idea, but I see some possible failure points that would really concern me. At the very least, I would carry my old stock plates, U-Bolts, and a couple new leaf pack center bolts with me when offroading. Not sure what that thin-gauge little piece of steel that sit atop the axle is going to do for lateral load... or even how to apply a lateral load exclusively to the spring pack. I really don't see a need for it, especially when you use oversized u-bolts. The design of the UB Skidderz and the "walls" that cup the springs prevent shearing of that pinn under lateral load. The spring pack "pin bolt" can be inverted to prevent shearing too. I've meaning to do that next time I get a chance to pull these off again. I need to resize the original jpeg's... No photoshop here yet. I did screen captures in MS paint to reduce them and saved them as .jpg. Not how MS paint works... it's still a .bmp apparently. I have to dedicate some time to do this. And I'm not selling these for Joe... It's a product I wanted and helped bring to the community and am glad to own. I just figured there would be others who might want something like this too. Compared to the stock design, I can't see where a "failure" is gonna occur. You'll break a whole lotta other stoff before these give way.
#58414 - 20/05/02 02:23 PM
Originally posted by Carlton McMillan: "Feel free to post any questions, concerns, bitches, gripes, complaints... etc."
You did ask for it though... I guess you're right. :rolleyes: I want make that an option next time. You'll take your post and like it.
#58415 - 20/05/02 05:52 PM
My concern about lateral load had nothing to do with the plate on top of the axle. I believe the main purpose of that plate is to help keep the U-Bolts from slipping apart, but I'm not sure. What I was seeing is there is space between the leaves and the bolts on the larger spring packs and I believe part of the job of the U-Bolts is to hold the elaves in place. The center bolt just isn't stron enough to hold up if there is side load on the springs. And if you think there isn't any side load, you should see what I've done to the brackets that wrap around my spring packs. Anyway, I think that the gap between the spring pack and the U-bolts should be filled either by steel plates or by pieces that fit over the U bolts above the Skidderz plate. As far as putting the center bolt in upside down I don't see how the nut would fit into the hole in the axle. The nut is larger than the round head of the bolt and that barely fits, unless you can find a smaller nut that fits over the bolt AND has enough strength to stay on. Ask XOC how much of a strength freak I am. I've pissed him off a few times over similar issues. Too many years around metal fabrication and construction will do that to an individual. When some folks in PNWX get their Skidderz it is almost a guarranty that I will be participating in the installation (they give me all the rear suspension shit to do!), so I'll get a closer look and will be ebtter able to evaluate. Until then I shut my mouth and rest my case! ![[Finger]](graemlins/thefinger.gif)
#58416 - 20/05/02 07:48 PM
Good plan... Let's let those who have ordered them comment after they've installed and tested them.
#58417 - 20/05/02 10:24 PM
Loc: Tacoma
I know Schludwiller and I ordered them. And ChuckH will undoubtedly help me with mine! I am sure they will work and Chuck will pull his head out of his butt!!!
-Rick
