#639241 - 10/03/05 07:39 PM Installed FIPK, What goes on the vacuume fitting under intake?
up4speed Offline
Loc: Lake Grove, NY
I just finished, but it looks like there is a fitting that a vaccum hose belongs on. It's right under the intake tube. I don't remember anything on there from stock. What is that tube?
2000 SE 4X4 Auto (Silver Ice)
#639242 - 11/03/05 05:45 AM Re: Installed FIPK, What goes on the vacuume fitting under intake?
On my 04 there is a metal tube, approx .25" dia. with no hose connected. It came that way.
#639243 - 13/03/05 04:39 AM Re: Installed FIPK, What goes on the vacuume fitting under intake?
I had the same thing on my '03. If this is similar to what I have seen on other vehicles and what I've been told, it's something that is used to balance out manifold pressure with atmospheric pressure. Not too sure about that...might want to ask one of the Nissan Gurus. confused
#639244 - 18/03/05 12:26 PM Re: Installed FIPK, What goes on the vacuume fitting under intake?
It is your seleniod tube. My 03 had a hose so I attached the factory hose to the FIPK one. If your X doesn't have one then you should have a plastic plug to plug up the hole that came with your kit.
