#642371 - 30/05/06 02:56 PM Small problem with Nismo Cold Air Intake Instalation.
paulgw Offline
Loc: St.Albans, Herts, UK.
I've just installed the Nismo Cold Air Intake (16576-RND25) on my 2001 Xterra and I have one question and a couple of small problems with the installation.
1: Is the air filter supplied "pre-oiled" or do I have to spray the filter with K&N filter oil? This is not stated in the instructions.
2: The heat shield appears to be about 1/2" too tall. After installing the new intake, I cannot close the hood properly. Is there a smaller heat shield available or can I just cut about 1/2" off the bottom of the heat shield?
3: The 3/16" hose, which at one end attaches to the MAF sensor adapter pipe and at the other end, a vacum fitting on the vehicle. I'm not sure, but my 2001 Xterra does not appear to have a vacum fitting at the other end.?
Any ideas guys? confused
Thanks,
Paulgw.
Email me if you live in the UK and own a Nissan Xterra. I know I'm not the only one, I saw a yellow Xterra on the M4!
#642372 - 31/05/06 06:49 AM Re: Small problem with Nismo Cold Air Intake Instalation.
The 3/16" line should be the one seen here, follow the Volant logo orientation up/right to the edge of the box, you'll see the line from that point to the fitting on the bracket directly to the left of the hood bumper on the fender.
#642373 - 01/06/06 08:47 AM Re: Small problem with Nismo Cold Air Intake Instalation.
paulgw Offline
Thanks for the info' and the photo, mate.
But my 2001 Xterra definately doesn't have anywhere for the 3/16" pipe to go!
What does the 3/16" pipe eventually connect to on your Xterra?
Thanks,
Paul.
#642374 - 01/06/06 10:49 AM Re: Small problem with Nismo Cold Air Intake Instalation.
I'm pretty certain that's just a feed to the MAP/BARO solenoid, which directs the input to the pressure sensor from either the manifold or the ambient air depending on whatever parameters determine which is needed. The line in question just goes to the airbox ahead of the filter to supply the BARO input, which is essentially just getting a reading equivalent to anywhere else, you can just leave the line disconnected and it shouldn't know any different.
#642375 - 01/06/06 06:49 PM Re: Small problem with Nismo Cold Air Intake Instalation.
If its a real K&N it should be pre oiled. It Should be a reddish color. If its white then it needs oil.
#642376 - 08/06/06 09:39 AM Re: Small problem with Nismo Cold Air Intake Instalation.
Solar Offline
Loc: Massachusetts
Offroad, how do you clean that engine? that looks brand new, sweet !
[Wave]
The reason why a dog has so many friends is that he wags his tail not his tongue!
#642377 - 08/06/06 10:15 AM Re: Small problem with Nismo Cold Air Intake Instalation.
socalpunx Offline
It's not his truck in that pic.
#642378 - 08/06/06 12:34 PM Re: Small problem with Nismo Cold Air Intake Instalation.
Yeah, mine's blue, and pretty grungy. That pic is from Volant's site, just handy for reference.
