0 registered (), 433 Guests and 2 Spiders online.
#643508 - 24/02/05 08:19 AM FIPK2 and CAT BACK
after freeing up the engine . Is it neccessary to tune the computer again after replacement?. And if so what programmer to use. All I see is for American only programmmers?
#643509 - 24/02/05 09:16 AM Re: FIPK2 and CAT BACK
I don't understand your question...
Are you asking if you should disconnect the battery when you install an intake? My answer would be yes. I think of it as installing new software on a computer. But I'm sure you don't have too.
Programmer? What are you talking about? Specifiy your question.
#643510 - 24/02/05 09:42 AM Re: FIPK2 and CAT BACK
well I am half asleep as we leave Hawaii. I meant to say tune . Is it neccessary to retune the computer after an Setup REPLACEMENT.I was told if I take it in to the shop they will set the computer up to fatory specs. A programmer lets you set the limits of shift points etc... and removes rev limiter
#643511 - 24/02/05 10:17 AM Re: FIPK2 and CAT BACK
fastdrmr Offline
Loc: SLC, UT
I did both of these on my 2001 and did not have to take it anywhere. The computer adjusts itself and it works just fine. Don't think I have ever read of anyone "linking" their ECU to refine the specs.
Just drive and it will use the better breathing and farting to your pleasure! laugh
KE7AEY
#643512 - 24/02/05 10:19 AM Re: FIPK2 and CAT BACK
The computer will re-learn eventually. The best idea is to disconnect the battery for about 20 minutes or disconnect the battery and hit the brake pedal for a couple of minutes to drain it faster.
That way it will reset the ECU and you'll have a better impression of what effect the new mod has accomplished.
