Yesterday at 10:44 AM
0 registered (), 239 Guests and 0 Spiders online.
Page 2 of 5 < 1 2 3 4 5 >
#661197 - 05/06/01 01:33 PM Re: Sick of vent blowing warm air? Try this...
Gator Saver Offline
Loc: Lakeland, FL
I see now, thanks
Gator Saver
2000 Blue SE 4x2
Florida Xtreme Xterras
Real Men Wear Kilts
Real Men Wear Kilts
Member number #112 Aug. 20, 2000
#661198 - 05/06/01 02:55 PM Re: Sick of vent blowing warm air? Try this...
Hmm, I seem to recall my switch had about half a dozen wires coming off of it, but that was ages ago. Same difference though.
#661199 - 16/06/01 01:13 PM Re: Sick of vent blowing warm air? Try this...
Chris Mc Offline
Loc: St Charles, MO
For those that did the cutting, how's it holding up? Just looking for a "status report" on if you've had any problems, etc.
Thanks!
Join the Heartland Xterra Owners Club at www.hxoc.net
#661200 - 17/06/01 04:41 PM Re: Sick of vent blowing warm air? Try this...
Gator Saver Offline
Loc: Lakeland, FL
At the X Plant tour I saw that a few X's have wire under there plastic. The owners of the X's got them in June July. I got mine in Feb and my plastic holes are blocked. Is this something they changed later on in 2000 ??
Gator Saver
2000 Blue SE 4x2
Real Men Wear Kilts
Real Men Wear Kilts
#661201 - 18/06/01 08:02 AM Re: Sick of vent blowing warm air? Try this...
anderair Offline
Loc: Denver, CO
No problems here. I did test the openings with a hose but the water all drained out behind the front mud flaps. The air is definitely cooler than before. However, it is 90 in Denver today so cool is relative.
To live is the rarest thing in the world. Most
people exist, that is all. - Oscar Wilde
Red Sox Nation - Colorado Chapter
#661202 - 21/06/01 05:59 AM Re: Sick of vent blowing warm air? Try this...
ChrisNYC Offline
Loc: Brooklyn, New Yawk
So, what is the final verdict for those that have done this mod? Is there truly a noticable difference in temperature after the vent holes have been enlarged? I really hate the fact that the air blows through warmer than it should, but I really don't want to spend the time and effort drilling out my truck if the result isn't that noticable.
#661203 - 21/06/01 07:37 AM Re: Sick of vent blowing warm air? Try this...
anderair Offline
Loc: Denver, CO
The air is definitely cooler and more comfortable. The time and effort are negligible - probably less than a 20 minutes with a cordless drill. Worth it for me.
"Lisa, if you don't like your job you don't strike. You just go in every day and do it really half-assed. That's the American way."
#661204 - 21/06/01 12:24 PM Re: Sick of vent blowing warm air? Try this...
Hank Offline
Loc: Tallahassee, FL
I'm not clear on where you guys are drilling the holes. And how many holes are you drilling? Pardon my ignorance...
2000 Yellow SE 4x4 5 Speed
"Never judge a person's horsepower by his exhaust."
Asian Persuasian
#661205 - 21/06/01 12:55 PM Re: Sick of vent blowing warm air? Try this...
cabin fever Offline
Loc: new jersey
Hank - look in front of the windshield wipers and you will see a grid pattern of squares. The bottom of each square needs to be poked or drilled out to allow greater airflow into the intake vents.
Look what I did to you ... AGAIN!!!
"Hunting sober is like fishing.....sober." - Uncle Jimbo
#661206 - 21/06/01 01:22 PM Re: Sick of vent blowing warm air? Try this...
dvd-man Offline
Loc: Rochester, NY
Well, I've been waiting for someone to post, "Don't do it!" but nothing so I guess I'll give it a shot.
Thanx guys.
'01 SE Silver Ice 4X4
'01 SE Silver Ice 4X4, oh... and SEARCH THIS..|.
#661207 - 21/06/01 05:36 PM Re: Sick of vent blowing warm air? Try this...
XID_dup1 Offline
Loc: Phoenix,AZ
I drilled out the holes about a week ago, and really havn't noticed any diff in the temp. Of course it's been 110 here, but at night when it cools down to 90, the outside temp feels much cooler than what is comming out of the vents. Which in itself is a real sad statement.
Any one have any other suggestions?
Andy
XID (X=Cross, ID = Eyed) Heb 12:2
Moses, my 2001 SE Silver Ice 4X4
Member: AZXC
#661208 - 22/06/01 05:50 AM Re: Sick of vent blowing warm air? Try this...
SurfX Offline
Loc: Jackson,N.J.
Punched mine out yesterday, quite an improvement. Nothing like an easy fix.
#661209 - 23/06/01 11:48 AM Re: Sick of vent blowing warm air? Try this...
Hank Offline
Ok...I got the drill out today and went to do this mod, but I found some things perplexiing. On the driver's side, the squares in front of the wipers didn't have anything for me to drill, just this screen type thing. Now when I went to the passenger side, I saw that there was a piece of plastic under the screen (the plastic piece was not as wide as the screen), so I drilled some holes in there (just some since I didn't know if I was doing the right thing)...did I do this mod right or should I drill more holes? Or should I drill holes in the screens? Help!!!
[This message has been edited by Hank (edited 06-23-2001).]
Asian Persuasian
#661210 - 23/06/01 09:19 PM Re: Sick of vent blowing warm air? Try this...
Hank Offline
So all of the drilling needs to be on the passenger side seeing there doesn't seem to be anything to drill except screen on the driver's side? But from what you said Paul, I shouldn't drill the plastic under the screen on the passenger side as this will suck in water and debris...but some on this thread have mentioned that water and debris have not been a factor in this mod. Still confused on what to drill and what not to drill...
Asian Persuasian
#661211 - 24/06/01 11:25 AM Re: Sick of vent blowing warm air? Try this...
Hank Offline
GHETTO!!! I've made this mod a lot more difficult than it was intended to. I think I've got it now --- logic has finally set in. Was I supposed to just drill the squares on the screen creating square openings instead of the plastic covering up the squares? When I say plastic covering the squares I mean, the plastic looking like crosshairs going across each square...
Asian Persuasian
#661212 - 24/06/01 11:51 AM Re: Sick of vent blowing warm air? Try this...
How does one remove the plastic between the hood and windshield anyway? I don't see any way to do it. Also looks like I'd have to remove the wiper arms, but that too looks like a trick.
#661213 - 24/06/01 07:57 PM Re: Sick of vent blowing warm air? Try this...
XterraIncognita Offline
Loc: Ann Arbor, MI
Originally posted by *paul:
Personally I don't agree with this mod
*paul, why? Is there something odd/useful/dangerous we should know here? I ask because it seems to me the grid in mine (undrilled as of yet) has molding errors. A few of the vent holes are fully open, some are partially open, many are completely plugged, and there doesn't seem to be any clear pattern as to which are open and which are not. This randomness leads me to the conclusion that Nissan has some minor flaws in their manufacturing of this part that they choose to ignore.
Just curious. Pro AND con info is always useful, you know?
And I agree... a picture is worth a thousand words here. Anybody want to post a couple?
Matt
2001 SE Solar Yellow 5 speed
[This message has been edited by XterraIncognita (edited 06-24-2001).]
--Matt
#661214 - 25/06/01 06:33 AM Re: Sick of vent blowing warm air? Try this...
ChrisNYC Offline
Are we all talking about the same part of the vent? A few before / after photos here would really help. Anyone with a digital camera handy?
#661215 - 25/06/01 07:24 AM Re: Sick of vent blowing warm air? Try this...
Chris Mc Offline
Loc: St Charles, MO
I'll take some pic's at lunch. I'm *fairly* sure I know what you guys are talking about... Haven't drilled yet myself, but will soon. Actually I'll probably use a dremel tool, should be easier.
#661216 - 25/06/01 07:55 AM Re: Sick of vent blowing warm air? Try this...
There is a pic or two that might be of some interest here You can at least see some of what is under the plenum.
#661217 - 25/06/01 11:11 AM Re: Sick of vent blowing warm air? Try this...
TimR Offline
Loc: Forest Lake, MN
One would have to be spectacularly ham-fisted to drill through the covering of the fan. The holes are no bigger than the holes that were originally molded into the grate, just a poor molding job left them partially plugged. One really could spend 5 minutes with a rusty nail to pop out the "chads", there is not need for a drill, except that it is a cleaner hole.
This, of course, is completely different for those of you with screens under the plastic grate.
TimR
XterraIncognita,
I would prefer a more professional-looking fix, and one that does not leave such large holes leading to the plenum area. There is insufficient protection left (IMO) to stop debris from going straight into the fan.
Remove the grill and check it out for yourself. The problem is more complicated than it appears from the outside, and yet can be resolved simply by using the A/C until a better solution is found.
#661218 - 25/06/01 11:14 AM Re: Sick of vent blowing warm air? Try this...
TimR Offline
Those pic's don't show at all what should be drilled. Sorry, I don't have a digital cam - but if you can look at just about any car parked next to yours and see the nice open intake grate - then look and see if where your Xterra has the holes not fully cleared - it should be obvious.
TimR
#661219 - 25/06/01 11:22 AM Re: Sick of vent blowing warm air? Try this...
Chris Mc Offline
Loc: St Charles, MO
OK, I have some pic's here that someone else can annotate for the correct spot to drill. http://linux.thoughtprocess.net/~chrismc/bezel/
The thumbnails are linked to very high-resolution images. If you need the photo hosted, email it to me and I'll post it on my site.
blah!
[This message has been edited by Caver-X (edited 06-25-2001).]
#661220 - 25/06/01 11:26 AM Re: Sick of vent blowing warm air? Try this...
TimR Offline
Beautiful. The second pic - see all the molding chads? Pop 'em out.
TimR
#661221 - 25/06/01 11:36 AM Re: Sick of vent blowing warm air? Try this...
Chris Mc Offline
Loc: St Charles, MO
Did you say "chad's"? Exactly what type of chad is that...?
blah!
