129
#673125 - 19/09/10 10:34 PM
Xterra will not crank
starter just clicks.batt good starter is new. have power to every thing. Help!!
#673138 - 20/09/10 04:32 PM
Re: Xterra will not crank
[Re: Gonzo-2]
I have 11.66 volts at rest on batt. 11.57 at main wire at starter and 11.46 at wire runing to starter from ignition. tahnks
#673139 - 20/09/10 04:34 PM
[Re: Gonzo-2]
it will not start from a jump. Thanks
#673141 - 20/09/10 06:14 PM
[Re: e207]
Lights stay on when I try to crank. I have no idea what else to check. I have checked all the wires at the key. All have the correct voltage. ??????????
#673144 - 20/09/10 07:40 PM
[Re: XOC]
State of Charge Specific Gravity Voltage 12V 6V 100% 1.265 12.7 6.3 *75% 1.225 12.4 6.2 50% 1.190 12.2 6.1 25% 1.155 12.0 6.0 Discharged 1.120 11.9 6.0 look about halfway down to see a better chart of voltage = amount of charge left. You may have some voltage.. but you are not pulling enough current. Thus no start. Replace your battery.
Edited by XOC (20/09/10 07:43 PM)
#673153 - 21/09/10 12:08 PM
[Re: XOC]
I'd want to know the age/info on the battery, if the alternator is working, and the answers to some of the unanswered questions in the thread...as the distributor, etc, can also be bad, yada yada yada....  If you have crappy cables, but another battery from something of appropriate power, you can swap batteries, and see if that fixes it. If not, its other stuff.
#673158 - 21/09/10 04:05 PM
[Re: XOC]
wouldn't it start from jump even if he battery was dead. with over 11 and 1/2 volts it should at least turn over. one would think! thanks
#673160 - 21/09/10 04:35 PM
[Re: XOC]
well its not the batt. just put the one out of my other car that has a charge of 12.4 and yes i looked at the charts
#673162 - 21/09/10 05:01 PM
[Re: msbelk]
well its not the batt. just put the one out of my other car that has a charge of 12.4 and yes i looked at the charts I think you're saying that you installed a different battery, with sufficient starting power (CCA, etc...) to start the truck, and it still doesn't start? A Car battery as you said, or a battery for a truck?
#673165 - 22/09/10 04:29 AM
[Re: _Craic_]
Loc: Lansing, Michigan
I think TJ was hinting at the idea of having enough CCA to crank the truck. That's all.
If the other battery DOES have enough CCA and it IS good, then after the swap it should start. Unless of course that's not the problem. I'd venture to say that if the original battery only has 11.something volts left, it's certainly bad. But here's where you have to speculate as we don't have more info. IF that is true, then the battery has most likely been in the truck for a long time. If that is true, then the cables are most likely original, and at this point, corroded internally and not carrying much power. Point being, if the cables are bad, and I speculate that they are, even a good battery will have trouble getting it to crank. Now if you try a different USED battery of unknown "good-ness", it may not work either, even though it may work in the vehicle it was borrowed from (different cables, better condition). This would also explain why it won't start from a jump.
So, all that being said, what's the power look like AT THE STARTER with the borrowed battery INSTALLED? (And that means installed, not jumped from it.)
-G
'03SE
BFG AT/KO Custom fuse panels for electrical mods Custom backup solution mod (lights/camera/monitor) Custom switched power outlets (8+ total) Lots-o-Lights (6 driving lights, 10 total)
Original registration - Sep, '03 Pre-crash post count - ~1100
#673168 - 22/09/10 05:59 AM
[Re: Gonzo-2]
/\ /\ /\ Yup And, the car engine (VG33E) uses a different flywheel for example (Lighter), and is easier to crank.  You can measure the continuity and resistance of the wires/cables if you have the meter, etc. I was also pointing out (Wanting to anyway...) that the battery could have been low simply from trying to start the engine with it a bunch of times... ...or because the alternator wasn't working... ...or because the old cabling was too lossy and power was being bled off too fast to replace, etc.
#673174 - 22/09/10 04:39 PM
[Re: TJ]
OK ITS NOT THE BATT!!!!!!!!i got a new one today. still the same.the starter engages but will not spin. its new i had them test before i left to make sure it worked.. Any other ideas?
#673175 - 22/09/10 07:02 PM
[Re: msbelk]
OK ITS NOT THE BATT!!!!!!!!i got a new one today. still the same.the starter engages but will not spin. its new i had them test before i left to make sure it worked.. Any other ideas? Yes....all the OTHER stuff we also mentioned.
#673179 - 22/09/10 07:43 PM
[Re: TJ]
thanks But you guys don't either.
#673197 - 23/09/10 09:21 PM
[Re: Gonzo-2]
Thanks guys! I am very thankful for your help I am just very frustrated. I am going to try to work on it again this weekend. Will try more tests Thanks again
