#673217 - 25/09/10 02:20 PM Ticking noise from front dash
Batman825 Offline
When I start my 2006 X Off Road there is a ticking noise coming from the dash in front of the passenger. It lasts a few seconds and then it stops. It sounds like a relay ticking. Any thoughts as to what it is?
#673218 - 25/09/10 03:00 PM Re: Ticking noise from front dash [Re: Batman825]
GARY 04 XTERRA Offline
Loc: WA, SOUTH KITSAP
FUEL RELAY? MAYBE
#673282 - 28/09/10 06:23 PM Re: Ticking noise from front dash [Re: GARY 04 XTERRA]
Chaz Offline
Loc: P.A.
more info needed. Does it happen in Park? Or right when you put it in drive? Everytime you start up? or just when the engine is dead cold?
#673287 - 28/09/10 07:32 PM Re: Ticking noise from front dash [Re: Chaz]
e207 Offline
Loc: Ashland, PA U.S.A.
does it make the noise if you turn the ignition all the way on, without starting the engine?
2002 SE/SC R.I.P. March 2015
Bielstien's
Shrock Sliders
Captain 38-90
#673636 - 26/10/10 09:19 AM Re: Ticking noise from front dash [Re: e207]
Slider Offline
Loc: Louisville, KY
Is it only when you start it for the first time in the morning or if it has been sitting for a while? Mine just started doing this also, I am pretty sure it is the lifters ticking. I asked the dealership about it when I had it in for service and they said it is normal for an Xterra to do it after 70K miles.
#673645 - 26/10/10 08:32 PM Re: Ticking noise from front dash [Re: Slider]
slantyshanty Offline
Loc: Northern Michigan
Do you normally run the fan? I think I had my fan on at least #1 for the first four or five years of owning my X. (2004 X) It started making that noise about a year ago. I just turn the radio up louder smile
#679407 - 07/11/12 08:24 PM Re: Ticking noise from front dash [Re: slantyshanty]
mark garrett Offline
Loc: Houston,Tx
did anyone find out what this is.
#679411 - 07/11/12 10:00 PM Re: Ticking noise from front dash [Re: mark garrett]
PsiFire Offline
I have similar. Only started to do it after I got a tune up. <shrug> No idea the cause.
2002 XE with Sport and Utility Package
Magnaflow Stainless Exhaust
Rancho RS5000 Shocks
#679414 - 08/11/12 12:42 PM Re: Ticking noise from front dash [Re: PsiFire]
Loc: Houston,Tx
had the tune up 9 months ago, just got the valve cover gaskets last week. It started 4 days after that. Cking behind them, found some broken clamps on upper firewall. Keep me posted on any progess, I will do the same. Shake rattle & roll.
