#673236 - 26/09/10 06:32 PM Where is the hose the ac condensor drip through.
52 Offline
Where is the hose for the condesor that lets the condensation drip out. Had some trouble with my ac. Its up and running but i dont see any drips, which is unusual. I wonder if the hose is clogged.
Check me out at: www.fishreapers.com
Mods: 2003 Granite NA 4X4, KN FIPK, PML, Poly Sway bushings, 32" BFG AT Ko
#673281 - 28/09/10 06:20 PM Re: Where is the hose the ac condensor drip through. [Re: 52]
Chaz Offline
Loc: P.A.
I know the some of the 05 and up xterra's have issues with the length of the A/C drain hose not being long enough. The hose that lets water drip to the outside is located on the passenger side firewall. You can access it, and see it by removing the passenger tire, it has a large rubber cover that covers the port where the water comes out. Nissan has a TSB for this and has a part number for a water hose that you cut and attach to the hose to lenghten the tube. Hope this helps.
#673364 - 04/10/10 11:58 AM Re: Where is the hose the ac condensor drip through. [Re: Chaz]
52 Offline
I found the hose. It leads down next tot the exhaust on the passenger side. The ac blows cold as ice, but i have still now seen anything drip out of there. It used to come out on a fairly regular basis.
