0 registered (), 161 Guests and 0 Spiders online.
#673442 - 08/10/10 07:04 PM Need Help with Oil Leak 2000 SE
lunkerhunter Offline
Loc: Bonita Springs, FL
I've got the oil smoke from valve covers problem but if one of the gaskets fail how much oil can come out? Like drip, drip, drip when I stop? I've got a drip coming off the back bolt for the exhaust manifold. What above there would be leaking? Thanks!
#673443 - 08/10/10 10:27 PM Re: Need Help with Oil Leak 2000 SE [Re: lunkerhunter]
ProjectPatt587 Offline
That is most likely the valve covers... When my gaskets went bad I was actually losing 1 quart per month through the valve covers.. replaced mine at 180K and they were hard and brittle and had cracked in a couple different places... You'll need the valve cover gaskets , a plenum gasket (had to get mine from dealer like $6) also since you'll have to pull the plenum to change the valve cover gasket on the left side, it's a great opportunity to change the plugs hassle free. Number six plug is a breeze with the plenum out of the way =)
Just know the plenum can be quite the b!t(# to get off, namely the coolant hoses on the back side next to the firewall...
Good luck hope this helps
#673446 - 09/10/10 07:48 AM Re: Need Help with Oil Leak 2000 SE [Re: ProjectPatt587]
e207 Offline
Loc: Ashland, PA U.S.A.
ummmm, I remember pulling my valve covers off without removing the plenum. I had to take a couple of items off going to the plenum, but not the plenum itself.
2002 SE/SC R.I.P. March 2015
Bielstien's
Shrock Sliders
Captain 38-90
#673447 - 09/10/10 10:08 AM Re: Need Help with Oil Leak 2000 SE [Re: lunkerhunter]
OK seriously how many hour job is it?
Would you do it again if you had to?
What's a fair amount to pay to have it done?
#673448 - 09/10/10 11:00 AM Re: Need Help with Oil Leak 2000 SE [Re: lunkerhunter]
It took me 3.5 hours to do mine. When I did it I pulled the plenum, cleaned the valve covers and gasket surfaces, replaced the plugs and wires, replaced the distributor cap and rotor button, and put it all back together.
I asked the dealership about doing it and they said since they had to pull the plenum and all to change the valve covers I was looking somewhere around $300 in parts and labor...
Doing this job myself was definately worth it.
