#673746 - 05/11/10 10:29 AM Seafoam treatment - Check Engine Light??
tbonez18 Offline
Ok so I did the Seafoam treatment for the first time to my 03 xterra. Everything seemed to go ok, lots of white smoke! But after I turned the engine off and restarted it again my Check Engine light came on? I drove it around the block but the light was still on. Does this mean something bad?
Has this ever happened to anyone before that did the Seafoam treatment? Will the light eventually go out on it's own or did I really just screw up my xterra??? Thank you
#673749 - 05/11/10 11:33 AM Re: Seafoam treatment - Check Engine Light?? [Re: tbonez18]
granitex Offline
Loc: Columbus. Oh
whats the code???
It is probably nothing, but you willnot know without the code.
#673751 - 05/11/10 03:22 PM Re: Seafoam treatment - Check Engine Light?? [Re: granitex]
e207 Offline
Loc: Ashland, PA U.S.A.
odds are its an emission code, but hard to say what directly. you sent a bunch of smoke through your entire system, it may clean up itself, but getting the codes read would be a good idea. that way you know for sure where the problem is.
2002 SE/SC R.I.P. March 2015
Bielstien's
Shrock Sliders
Captain 38-90
#673753 - 05/11/10 04:01 PM Re: Seafoam treatment - Check Engine Light?? [Re: e207]
tbonez18 Offline
I waited for a buddy of mine to get home from work because he has a code reader. Started the x up and no check engine light. I'm going to assume that everything is ok with it and that it cleared itself. But i still might go over tmr and check it out. I'm just glad the light went out. Thanks guys
#673755 - 05/11/10 06:57 PM Re: Seafoam treatment - Check Engine Light?? [Re: tbonez18]
granitex Offline
Loc: Columbus. Oh
if there is no light, than there is no need to try to pull them.
#673765 - 07/11/10 10:32 AM Re: Seafoam treatment - Check Engine Light?? [Re: granitex]
Gonzo-2 Offline
Loc: Lansing, Michigan
Ahem... There's a lot of codes that don't throw the SES light.
Maybe worth checking them anyway. It wouldn't hurt. You may not find anything, but it may be better to know for sure...
-G
'03SE
BFG AT/KO
Pre-crash post count - ~1100
#673787 - 08/11/10 01:12 PM Re: Seafoam treatment - Check Engine Light?? [Re: Gonzo-2]
tbonez18 Offline
Very true....
Trying pulling the codes yesterday and no codes came up! So knock on wood, hopefully I'm in the clear!!!
