#675218 - 28/03/11 01:41 PM Where is the fuel filter?
redsox021384 Offline
I've looked all over for the damn fuel filter. Is this something I can change myself? I've got a 2000.
#675220 - 28/03/11 01:58 PM Re: Where is the fuel filter? [Re: redsox021384]
skatchkins Offline
Loc: Glendale, AZ
Under the rear passenger side seat
My X
2003, 3" SL, 2" BL, 33"x11.50 BFG KM2's, 1.25" spacers, Shrockworks sliders & bumper, custom rack, Warn 8K, etc
HigherGround4x4.com
#675222 - 28/03/11 02:41 PM Re: Where is the fuel filter? [Re: skatchkins]
Gonzo-2 Offline
Loc: Lansing, Michigan
That being said, do a search on HOW to replace it. It's under pressure (most of the time I think) and there's a process to replacing it without getting gas sprayed everywhere.
Also, when you do, check the electrical contacts of the sending unit for corrosion. Common problem and some were recalled for this issue.
-G
'03SE
BFG AT/KO
Pre-crash post count - ~1100
#675223 - 28/03/11 03:34 PM Re: Where is the fuel filter? [Re: Gonzo-2]
52 Offline
It's hidden behind a protection plate bolted to the frame. Under passenger side at the front of the gas tank. Golf tees are a nice trick to plug then if the start to give you a gas shower
Check me out at: www.fishreapers.com
Mods: 2003 Granite NA 4X4, KN FIPK, PML, Poly Sway bushings, 32" BFG AT Ko
#675225 - 28/03/11 06:34 PM Re: Where is the fuel filter? [Re: 52]
granitex Offline
Loc: Columbus. Oh
Are you just changing the filter, or doing the filter and pump.
If it is just the filter, pull the fuse for it and hit the key a few times, it will bleed off the pressure.
Other than that all that you really need is a 10mm socket and a small screw driver for the hose clamps.
Also be prepared for broken bolts, they are small and like to seize. Just go easy and you will be fine.
#675342 - 11/04/11 10:50 AM Re: Where is the fuel filter? [Re: granitex]
Carnage Offline
Loc: East Texas
I just replaced mine yesterday on my 02. And even after relieving the pressure (Took out fuel pump fuse turned it over -stalled- and then crank several more times) gas sprayed a decent amount. Though I did mine from underneath (not sure if I could have reached it from the inside).
#675345 - 11/04/11 02:11 PM Re: Where is the fuel filter? [Re: Carnage]
granitex Offline
Loc: Columbus. Oh
Just think of how bad it would have been if you had not blead off the pressue,, And there is no way that you could get to the filter from the top, it has to be done from underneath.
