56
#675663 - 24/05/11 04:13 PM
Re: Unlocking and Locking a Door with the Key.
[Re: e207]
Loc: chicagoland
I have an 02 and the clip hole broke on my fob. I have been using the key only, for several years. And there are only 2 keyholes.
Therapy is extremely expensive, popping bubble wrap is radically cheaper, you choose which one helps with your problem, I'm gonna get some sleep!
#675701 - 30/05/11 02:46 PM
[Re: e207]
Loc: High Point, NC
gee, never noticed that there isnt one on the pass side door !!! imagine that, guess that shows how much I've tried to use the key !!1 lol 2000X's had one on passenger side door.
'00 4x4 V6 XE
#675705 - 30/05/11 11:27 PM
[Re: Lightning]
Loc: Utah
I've been using the key only for years now. And you know what, I got a copy made for 6 bucks and it works just fine too. But I do miss my fob. Note to self, don't take that up the mountain again.
Whoever it was that thought it was a good idea to put the alternator on the bottom of the engine owes me somewhere around 500$
#675775 - 11/06/11 10:06 PM
[Re: Jahadaz]
Loc: West Babylon, NY
I just bought 2 new key fobs on ebay that come with easy-to-use programming instructions. I'll let you know how well they work. I also have re-keyed vehicle ignition keys. The original the owner left with her mechanic by mistake. I have two copies. They both work in the lock and the ignition. Sometimes it may not turn the first time so I may have to flip the key over of back it off a bit so the teeth hit the tumblers.
#677243 - 11/12/11 02:28 AM
[Re: AnthonyS]
Loc: Santa Rosa, CA & Baja Sur
While we're on the subject, who designed that fob with the three in-line buttons. My old Ford had right/left lock/unlock with the panic button below - hard to accidentally push it. Nissan makes you feel in the dark for that middle unlock button so you don't push the panic alarm!!
2008 XTERRA Off Road
#677260 - 12/12/11 11:17 AM
[Re: e207]
Loc: California
Good experience with the after market new FOBs. Instructions were easy to follow and new one works great. Got mine from http://www.keylessride.com/
When hell freezes over, I'll ski there too!
#680567 - 10/10/13 11:07 PM
[Re: No Whining]
But i think when you use the key fob to lock and unlock the door you have a problem in your door lock sensor after few months.And due to that the ignition system don't properly work and alarm set off.So you must use the key to lock and unlock the door.
Only the insecure strive for security
#680576 - 13/10/13 12:12 PM
[Re: Deniel]
But i think when you use the key fob to lock and unlock the door you have a problem in your door lock sensor after few months.And due to that the ignition system don't properly work and alarm set off.So you must use the key to lock and unlock the door. Nope, the fobs work fine and there's no problems after a few years let alone a few months.
