#676903 - 05/11/11 06:43 PM Will old Pathfinder rims fit my 2009 X?
giovanni Offline
I have a set of the original alloy 6x139.7 15" rims off of my 93 Pathfinder.
I put 31" snows on them and used them on my 2001 X.
Now I have a 2009 X with the 6x114.3 bolt pattern.
I am wondering if I can use these 15" rims on my 2009 with the help of an adapter, found here:
http://www.ebay.com/itm/6x114-3-6x4-5-6x...r#ht_4012wt_754
Not sure if the 15" rims will fit over these calipers on the 2009.
Thanks!!
Edited by giovanni (05/11/11 06:44 PM)
#676906 - 05/11/11 09:46 PM Re: Will old Pathfinder rims fit my 2009 X? [Re: giovanni]
The brakes of the 2009 are too large to clear in a 15" rim.
You need at least 16" rims for that.
#676907 - 06/11/11 07:55 AM Re: Will old Pathfinder rims fit my 2009 X? [Re: TJ]
giovanni Offline
How about a set of 18" rims off of a Titan?
I can use the same adapter for the bolt pattern.
I found a local guy who is getting rid of his 265/70/18's snows off his Titan.
18" should clear the brake calipers right?
Will the 265/70/18 be OK in the wheel well for a 2009 X??
Does the 2008 Titan have wheel sensors?
Edited by giovanni (07/11/11 07:26 AM)
