147
#675413 - 22/04/11 11:03 AM
Re: headlight lens restoring? who's done it?
[Re: e207]
Loc: Utah
I bought a 3m set from my old work for about 15 bucks. It did work quite well considering how terrible they were. I've spent far to many nights on the beach with the salt water blowing on them so any improvement was a step in the right direction.
Be sure you really tape the heck out of your bumper though. I wasn't as careful as I should have been and there is now a little white were there should be gray. Not really noticeable, but I know it's there.
Whoever it was that thought it was a good idea to put the alternator on the bottom of the engine owes me somewhere around 500$
#675414 - 22/04/11 12:35 PM
[Re: Jahadaz]
Loc: Virginia
I used the one from advance, for i think around 20-25 bucks. It works really well, but you are never gonna make them look brand new.
#676005 - 10/07/11 12:13 AM
[Re: e207]
Used Meguiar's PlastX and the small mother's foam power ball. Worked great. Removing the headlight covers wasn't too bad.
2004 Xterra
#676012 - 11/07/11 09:00 AM
[Re: JWade]
You knuckle heads.  Just use toothpaste like everyone else has done for the past umpteen decades. (Not gel, paste...)
Edited by TJ (11/07/11 09:00 AM)
#676013 - 11/07/11 10:01 AM
[Re: TJ]
Loc: Florida
Just use toothpaste like everyone else has done for the past umpteen decades. (Not gel, paste...) I guess you mean something like Crest with the green and blue specs.  I would like to clean my headlight lenses. Would you mind explaining a good procedure to accomplish this with some toothpaste. What applicator should be used..... a sponge...etc.? Should up and down motions be used.... or circular motions? Inquiring minds want to know.
#676022 - 12/07/11 05:14 PM
[Re: NY Madman]
Just use toothpaste like everyone else has done for the past umpteen decades. (Not gel, paste...) I guess you mean something like Crest with the green and blue specs.  I would like to clean my headlight lenses. Would you mind explaining a good procedure to accomplish this with some toothpaste. What applicator should be used..... a sponge...etc.? Should up and down motions be used.... or circular motions? Inquiring minds want to know. LOL Yeah...wet a soft rag, squirt some paste on it, and gently rub it in a circular motion at one spot to see it clear/get the feel for it. You want it wet, so the teeny abrasives in the toothpaste gently grind off the oxidized surface plastic. Toothpaste is designed like a very fine wet sanding agent, to polish your teeth, w/o removing too much enamel, etc. Once you get a feel for it in one spot, move over to another, going as large as you feel you can control. Its pretty easy really.
#676024 - 12/07/11 06:01 PM
[Re: TJ]
Loc: Lansing, Michigan
And I thought NYMM was gone... How ya been? Haven't seen your right-wing conservatist BS on here for some time. No, wait. This should be in the Where's all the original club members? thread... -G
Edited by Gonzo-2 (12/07/11 06:05 PM)
'03SE
BFG AT/KO Custom fuse panels for electrical mods Custom backup solution mod (lights/camera/monitor) Custom switched power outlets (8+ total) Lots-o-Lights (6 driving lights, 10 total)
Original registration - Sep, '03 Pre-crash post count - ~1100
#676025 - 12/07/11 10:27 PM
[Re: Gonzo-2]
Loc: Florida
Yeah...wet a soft rag, squirt some paste on it, and gently rub it in a circular motion at one spot to see it clear/get the feel for it. You want it wet, so the teeny abrasives in the toothpaste gently grind off the oxidized surface plastic. Toothpaste is designed like a very fine wet sanding agent, to polish your teeth, w/o removing too much enamel, etc. Once you get a feel for it in one spot, move over to another, going as large as you feel you can control. Its pretty easy really. Thanks alot TJ. I'll give that a try. I have been noticing that when I look at my headlight lenses from different angles, that they seem fairly yellowish. I wasn't sure about whether cleaning would be a fix or just looking for new headlight lenses. Thanks for the info. And I thought NYMM was gone...
I have been very well Thank You. It's very nice of you to ask. I have also noticed that I have not seen any of your left-wing socialist type BS on the board either. But, then again, I have also noticed that you continue to post on the board. Yet I have not interrupted a single thread to mention your particular political persuasion. That is the difference between a conservative and a left wing socialist.
#676095 - 21/07/11 12:01 AM
[Re: NY Madman]
A parking lot security guard on Tijuana Mexico said "Boss, while you do your shopping, we have this headlight restoration service; Its only 100 pesos (8.5 dollars) and your headlights will look just fine" and I thought "hmmm how good can it possibly look? I mean, these plastics are 9 years old, but oh well, lets have it done". OMG how wrong I was; He did a fantaastic job. I am sooo happy with my new headlights.
#676980 - 14/11/11 06:47 PM
[Re: Seinto]
I used crest pro-health on mine today...not only looks good, but the front of my truck smells great.
2000 XE PMBL, K&N, GARMIN 76-CSX, CRUSTY FUEL SENDING UNIT, RUSTY CRAGAR D-LOCKS, CRACKED EXHAUST MANIFOLD
#677082 - 21/11/11 05:06 PM
[Re: k_enn]
Loc: California
I'm with k_enn on this one. I had some rubbing compound and polish in the bottom drawer of the tool box. Added a little water to the rubbing compound and finished off with polishing. Not only did the lenses clean up real well, they shed water/dirt etc. much easier.
When hell freezes over, I'll ski there too!
#679805 - 28/02/13 08:29 PM
[Re: No Whining]
Try this for a cheap..i mean very cheap clean..spray Deep Woods Off bug spray on a towel and wipe on the fogged lens. I was told this and tried it and it WORKED ! !
#680279 - 10/07/13 02:00 AM
[Re: ]
__________________ There're a lot of information about that tatooed on my ass, hope you can get something what you need.
#680346 - 26/07/13 05:29 AM
[Re: TJ]
Loc: cooper, tx
