230
#677454 - 27/12/11 04:57 PM
Re: Keyless Entry Help!
[Re: RNTKnives]
If the programming procedure for the newer Xterras is anything like the one for the older ones it involves getting the computer into learn mode by pushing a bunch of buttons (like, turn the key to accessory, push the door lock button xx times within yy seconds, then blah blah blah - now you're in program mode, hit any key on the remote and it will be learned)... they make it complicated enough that you won't stumble onto it with normal use but once you know it it's easy and doesn't require any tools or a special programmer or anything.
#677460 - 28/12/11 11:20 AM
[Re: Kaiser]
Loc: California
Kaiser is right, the programming is dead easy. I ordered replacements for my wife's van and my X from keyless ride. http://www.keylessride.comPrice wasn't the ~$10 quoted in this thread, but they were brand new and worked as advertised.
When hell freezes over, I'll ski there too!
#677462 - 28/12/11 04:21 PM
[Re: No Whining]
Loc: Upsate NY
programming
1. close all doors
2. insert and remove key from ignition switch more than 6 times within 10 seconds.(indicators will flash twice)
3. insert key and turn to ACC
4. press any button on first remote to be programmed (indicators will flash twice)
5. oldest remote transmitter codes is now erased
6. To program next remote :unlock then lock using drivers side door control panel :press any button on second remote to be programmed(indicator lights will flash twice to confrim)
7. Repeat for more remotes
8. To exit programming open drivers door
Edited by fuzzytek (28/12/11 04:22 PM)
#680931 - 12/02/14 01:14 PM
[Re: fuzzytek]
I have a question, my xterra used to beep when I locked with my keyless remote, but now it doesn't...I liked the beep because I knew it locked, any ideas what the problem could be?
thanks!
#680932 - 12/02/14 01:34 PM
[Re: barby6922222]
