116
#680545 - 03/10/13 05:43 AM
Muddin' the X!
Loc: Mount Laurel, NJ
OK, last week I installed some Mickey Thompson STZs in 265/75 16s on my X; then on sunday went for a ride in Wharton with a Jeep JK, an XJ, and a Toyota 4x4. I led the group on the powerline trail. I was surprised & amazed at how the X went everywhere the Jeeps went without getting stuck. Got into some heavy sand and some deep black mud holes. My friends who made fun of the X when I got rid of my TJ couldn't believe it. Had a little bit of rubbing in front, does anyone know how many turns per inch on the T-bars for a PML? Thanks
Brad
#680555 - 07/10/13 04:34 PM
Re: Muddin' the X!
[Re: Xwrench]
Brad Sounds like fun! Are you going back 10/27 (SUNDAY) for the Annual Pine Barrens Clean-up Run? There is NO number of t-bar rotations to get a PML...as every bar is different...even left and right bars on the same truck tend to need different numbers of turns, etc. The way you do it is to adjust the bar until you have ~ 1/2" to 3/4" of upper (UPPER) bumpstop gap left....and that's ~ the PML limit of adjustment. And, for the record, it won't stop tire rub upfront. It only adds tire clearance at RIDE HEIGHT. (As all suspension lifts (SL) do) When you go over a bump, the tires rises up to exactly the same point...and whatever it would have hit before the SL, it hits after the SL too. As you only have 32x11.5 sized tires, they fit with some trimming. Cut off the soft plastic ledge at the rears of the front wheel wells, where the lower mud flap used to screw into. That's the main place that usually hits...and which can jam the tire and stop you.
#680613 - 22/10/13 06:21 PM
Re: Muddin' the X!
[Re: TJ]
OK, followed your advice, got considerable lift, and did some trimming. Went out last Sunday w/Dominic & a bunch of Jeeps. No rubs, went through lots of bad stuff & had a great time. Only got stuck once. Got a shackle kit for the back, also. Trying to make the clean-up.
Thanks for your help,
Brad
#680614 - 22/10/13 11:00 PM
Re: Muddin' the X!
[Re: Xwrench]
Brad Sounds Good! I look forward to meeting you in person on Sunday!
#680618 - 23/10/13 05:46 PM
Re: Muddin' the X!
[Re: TJ]
Wanna lock one of the diffs, like lockrights & Aussies, etc., any ideas?
#680637 - 26/10/13 08:49 PM
Re: Muddin' the X!
[Re: Xwrench]
The only actual locker option is an ARB air-locker right now....which is expensive, but works great.
#680806 - 29/12/13 11:15 AM
Re: Muddin' the X!
[Re: TJ]
Once again, the black sheep! went out last Sunday with about 10 assorted Jeeps, from stock to heavily modified. Got some skeptical looks when we all met up at the Pic, but after blasting through some serious mud, received many props on the "nice build". didn't get stuck at all, went everywhere they did. I'm finding that it's a different driving style, leave lots of room at the end, and power through hard, lots of throttle. Really enjoying this truck!
Brad
2002 X, M/T 32's, 2 1/2-3inches, lots of trimming.
