0 registered (), 67 Guests and 1 Spider online.
#682449 - 27/03/14 12:35 PM distributor
JEH Offline
my dtr 2000 tach will start to jump around 2500 RPM changed plugs,fuel filter,roto cap and roto bug. read a lot and possibly the distributor is going bad need help
#682451 - 28/03/14 02:44 PM Re: distributor [Re: JEH]
JEH Offline
reposting newbe to xterra my daughters 2000 xterra,s tach starts to jump around between 2000 abd 2500 RPM,s. I have replaced the plugs,fuel filter,roto cap and roto bug and it is still doing the same. I have read on line about the distributor going out. at first thought it was the fuel pump but my experance is the fuel pump just goes out. I need help with my daughter apprx 2-3 hours away from home in college cant afford to have a lot of trouble. should I replace the fuel pump or the distributor ther is a loose of power also
Edited by JEH (28/03/14 02:45 PM)
#682472 - 17/04/14 10:13 AM Re: distributor [Re: JEH]
Kaiser Offline
It might be the throttle position sensor, which is easy and cheap to replace. Also, the distributor can be fixed for around $10 by replacing the bearing in it if you know what you're doing.
