44
#678539 - 13/05/12 11:03 PM
Re: How many miles on you x
[Re: slantyshanty]
Loc: Lakeland, FL
93,350 today Bought it with 36 miles on it in 2000. We use her Highlander Hybrid for everything now.. 24mpg.. beats my 12mpg
Real Men Wear Kilts Member number #112 Aug. 20, 2000
#678588 - 20/05/12 08:01 PM
[Re: Mobycat]
Loc: Wa.St. Seattle,King
How may clutches have you gone through in 156,000 mi.? Been reading about tons of clutch failures on 2nd gen. Manual Off roads. I have a 2006 with 38,000 mi.
Edited by Fang (20/05/12 08:50 PM) Edit Reason: put 38 not 38,000mi.
Fang. Have no idea of what a UBBCode is. This site had to have been set up by a person under 50. Don't get it.
#678677 - 06/06/12 12:38 PM
[Re: Tradhunter]
Loc: Ontario
#678685 - 06/06/12 07:23 PM
[Re: Cliff]
I bought my 06 off road in April 2006. I worked out of town for until 2008 so it didn't get much mileage on it. I now have 43500 since I am now retired and drive it a lot more. Noticed that the fuel economy, If you can call it that in an Xterra, has gone down lately. I am going to run some injector cleaner through it this week and see if that helps. Your plugs might be getting a bit long in the tooth, and, MAF cleaner might be a good idea too. Its also possible that you need to change some lubes other than engine oil, like in the diffs, etc.  Going full synthetic saved me a ton o $
#678697 - 08/06/12 04:34 PM
[Re: Cliff]
Loc: Wamego ks
2004 XE. 114000 head went at 93000. Still needs tranny flush and fresh front and rear gear
Edited by Weak04XE (08/06/12 04:35 PM)
3.3 to push 5200lbs.? Well it kinda works just wish I had 6 speed
#678891 - 10/07/12 09:44 AM
[Re: baf6]
Loc: Riverdale, New York, USA
My 04 X had around 59K when I traded it in yesterday.
Currently 2012 Pro-4 Xterra Night Armor Prior owned 2004 XE Xterra Silver
#679221 - 19/09/12 12:15 PM
[Re: baf6]
I have a 2012. Just picked up last week.....900km's.
Dave 2012 Xterra S
#679223 - 19/09/12 04:29 PM
[Re: 17A]
2002 XE with about 133k miles on it. Only broke down on me twice:
Starter failed while on vacation last year at about 120k. Brake line rusted through and pissed brake fluid on the manifold causing a "small fire" earlier this year.
2002 XE with Sport and Utility Package Magnaflow Stainless Exhaust Rancho RS5000 Shocks
#679231 - 21/09/12 01:32 PM
[Re: PsiFire]
Loc: Idaho
My 2012 S has 1110 miles on it which is a replacement for my 1990 Suzuki Samurai which was wrecked in June 8^(
#679312 - 19/10/12 08:18 AM
[Re: turboprop]
Loc: Paint Lick, KY USA
May 1999 Xterra XE Automatic 181,xxx miles. Just replaced a starter (original)last month. Other than normal maintenance and valve cover gaskets, no major failures. I do have a hole in the passenger side rocker panel from a meeting with a rock years ago and a couple of bubbles of rust on the passenger side rear wheelwell and one on the hatch. Just drove it 3100 miles to Moab to camp and wheel for a week. It always has been under powered in my opinion but this time across Vail Pass on Route 70 was 40 mph... and I was not even towing my camper. Looking at one of the new Pro models...
Coolerman Past Member of MAXC/TLCA 2000 V6 Auto SE Xterra 2013 Altima SV 1971 Toyota Land Cruiser
#679356 - 25/10/12 01:21 PM
[Re: coolerman]
Loc: Georgia
114,700. Currently on my: Second timing belt, Second set of shocks & brakes, And third set of tires.
I went from single in college to married & two kids under the same rack.
I'll update XOC again when I'm on my third timing belt.
Cheers
"Everybody to the limit, the Cheat is to the limit, everybody come on Fhqwhgads!"
#682980 - 09/04/16 06:34 AM
[Re: DocNo]
2005 190k 6 sod. Clutch is still perfect. In fact just test drove a 2015 and it felt mushy. My timing chain needs replacement. Rear seals always fail on my axel. Replaced numerous times. Looking to trade it out for a 2015 Xterra. Love the vehicle.
#682982 - 10/04/16 03:17 PM
[Re: Oharag]
Year 2000. Just turned 92k
#682998 - 22/08/16 06:47 AM
[Re: baf6]
'03' with 150K. Brand new (to me) runs great, but a small oil leak that fouls the starter motor. The mechanic says he fixed the oil leak, but there are still a few tiny spots on the cement. I like this car a lot, but the stereo is for modern younger technologist, not old men. But I'm figuring it out.
#683028 - 05/03/17 03:22 PM
[Re: Randy Howerton]
Loc: Pennsylvania
51000 on my 2004. I was an original or so member here. I wonder who is still here.
Thomas "A great civilization is not conquered from without until it has destroyed itself from within."
#683030 - 07/03/17 02:18 PM
[Re: Canope]
2003 X here bought with 74K on it in '06. Went to 196,000 (over 10 years) before it was rear ended by a tractor trailer at 20mph and totaled. Had just put fresh tires on it at 195,850!! I'm sure it would have gone the distance. RIP ONYX
#683063 - 22/01/18 10:04 AM
[Re: Oceancitysurf77]
Update: Now at 208,563 and have several issue to fix as it sat for about a year after getting the 2012 Pro-4X.
Exhaust and brake work is in my future!
#683120 - 28/09/19 12:31 PM
[Re: Tradhunter]
234,000 on the 2004. Still humming.
#683123 - 03/11/19 02:25 PM
[Re: Nail Bender]
Loc: Franklin, NH
2011 Pro-4x with 105,000 miles.
You can't tell which way the train went by the tracks it left behind.
