Yesterday at 10:44 AM
0 registered (), 191 Guests and 0 Spiders online.
Page 1 of 3 1 2 3 >
#70930 - 12/05/01 03:18 PM Sgt_Lobo's Shelf Modification
Sgt_Lobo Offline
Loc: Ocean Springs, MS
This is an idea I came up with on a long road trip to Texas. When I was packing the Xterra, I realized I just didn't have enough storage space for the tools, flares, and everything else I carry with me everyday. So when I got to Texas I told my friends I wanted some sort of shelf in the back of the X. After about a 6 pack, we came up with the idea for this:
The shelf and drawer I purchased at a place called The Container Store in San Antonio.
I attached the shelf by pulling out the tiedowns in the roof. Up front I used a long bolt and two large washers with a nut above the top washer to keep it tight. In the rear, I fashioned two brackets from some steel I purchased at home depot. You will also notice that I had to remove some material from the corners of the shelf in order to get a good fit and prevent it from hanging too low.
Here are some more pics:
And a shot from the rear view mirror:
As you can see, the drawer cuts out a little bit of my view from the rear view, but not too much. I have also since made some other modifications. I placed some clear tubing around the rods that support the drawer so now I don't need the bungy straps to keep the drawer from sliding. I also put the same clear tubing around the sections of shelf I cut to help protect the X from being scratched.
Well, that's about it. I hope you all enjoy.
Sgt_Lobo
2000 4X4, SE, White
http://www.cableone.net/sgtlobo/xterra.htm
Sgt_Lobo
"when my x grows up it wants to be just like that!"
#70931 - 12/05/01 03:30 PM Re: Sgt_Lobo's Shelf Modification
satrider Offline
Loc: South FL
Great Idea Stg!!
Is that an amp I see up there on the rack? I thought about doing something like that too. I was going to build an amp rack since I do not want audio amps taking up cargo space.
'05 Silver Off-Road 4x4
"Screw milk, got Xterra?"
#70932 - 12/05/01 04:52 PM Re: Sgt_Lobo's Shelf Modification
Sgt_Lobo Offline
No amp, mine is under my passanger front seat. But that isn't to say you couldn't put one up there if you wanted.
Sgt_Lobo
2000 4X4, SE, White
Sgt_Lobo
#70933 - 12/05/01 05:20 PM Re: Sgt_Lobo's Shelf Modification
ChuckH Offline
Dang...you stole my idea! I was thinking of putting something up there too just to hold small light things. Of course your version is much better looking than what I might have come up with! The only suggestion I would have is that you enclose the front facing side better so stuff won't fly forward in the event of an accident. hopefully you won't have to worry about that, but better safe than sorry! Looks great man!
2000 SE 4x4, Aztec Red
#70934 - 12/05/01 05:23 PM Re: Sgt_Lobo's Shelf Modification
PlayHard Offline
Loc: Canada
That is a wicked idea! Are you concerned about the amount of weight being supported? I've done a similar temporary mod with a cargo net, but nothing quite like that. Good job.
SOXC Member
www.soxc.org
www.soxc.org
#70935 - 12/05/01 05:23 PM Re: Sgt_Lobo's Shelf Modification
BoarderPhreak Offline
Loc: Huntington, NY
Should be interesting to see what you guys come up with after a twelve pack!
Damn, that's nice man. Clean install, nicely done and serves a very useful purpose. Props!
01 SE 6cyl 5spd Solar Yellow
#70936 - 12/05/01 06:23 PM Re: Sgt_Lobo's Shelf Modification
xcanuk Offline
Loc: Mtl. Que. Canada
Nice job, I guessing you load the shelf from the front of the shelf, within the X and not from the rear. Do you think it could be hinged, so it drops down, load, and clip back up ?
member of http://www.soxc.org
http://www.geocities.com/x_canuk
#70937 - 12/05/01 07:01 PM Re: Sgt_Lobo's Shelf Modification
Sgt_Lobo Offline
Thanks for the comments..
Yes, you load it from the front (the back seat area). The drawer however pulls out towards the back of the X.
I never really though about using a hinge system. I've never had any problems loading or onloading it.
As far as things flying off of it, nothing has yet. It has a rim around it that stands a little over an inch high which keeps everything in there nice and secure. Nothing slides around and nothing falls off. I've had it off-roading several times and have also made several hard stops and nothing has shifted. I still keep the bungy coard hooked on the handle of my toolkit just to make sure it is secure.
As far as supporting the weight, those tie-downs are pretty beefy and nothing has loosened up on me so far (I've had this shelf in for about 7 months now).
Sgt_Lobo
2000 4X4, SE, White
Sgt_Lobo
#70938 - 12/05/01 11:22 PM Re: Sgt_Lobo's Shelf Modification
Loc: Huntington, NY
...and you're just telling us now?
You holdin' out on us, sarge?
#70939 - 13/05/01 06:26 AM Re: Sgt_Lobo's Shelf Modification
Sgt_Lobo Offline
I've been uh, ummm, busy. That's it... Actually it's been a combination of laziness and problems loading web pages to my server that finally got resolved...
Sgt_Lobo
2000 4X4, SE, White
Sgt_Lobo
#70940 - 15/05/01 06:51 PM Re: Sgt_Lobo's Shelf Modification
incogneato Offline
Loc: Charlotte, NC
He must have been busy feeding the homeless and finding the hungry a place to live
Carl
2000 Silver Ice SE 4x4
Florida Xtreme Xterras
#70941 - 16/05/01 08:17 PM Re: Sgt_Lobo's Shelf Modification
Matt Peckham Offline
Loc: Charlotte, NC
that is a truly cool Mod. I may be attempting this later this summer.
Matt
I've been hacked by PoizonBOX.
The Van LIVES.
#70942 - 17/05/01 07:39 PM Re: Sgt_Lobo's Shelf Modification
*paul Offline
Loc: New Zealand
I made one last Feb for a VCR. The four (existing) mount points are not overly strong so be cautious about weight if you design your own.
[This message has been edited by *paul (edited 06-04-2001).]
-Paul
2007 Nissan X-Trail
New Zealand (ex San Diego)
#70943 - 18/05/01 08:20 AM Re: Sgt_Lobo's Shelf Modification
Loc: Huntington, NY
A VCR? Do I really wanna know?
They do make 12v, miniaturized VCRs that might be more compact. There are also a variety of LCD screens that you can use with them, but I'm assuming you already have such a setup?
Nice stash box, though.
#70944 - 18/05/01 10:17 AM Re: Sgt_Lobo's Shelf Modification
*paul Offline
Loc: New Zealand
No, you don't
I wanted a 27" TV so I wouldn't have to squint while I'm driving
Thanks, I had the sheet metal bent up by a local shop directly from a CAD model.
[This message has been edited by *paul (edited 05-18-2001).]
-Paul
2007 Nissan X-Trail
#70945 - 18/05/01 01:51 PM Re: Sgt_Lobo's Shelf Modification
Philosopher Offline
Another very cool mod. Nice work Lobo.
#70946 - 27/05/01 09:26 AM Re: Sgt_Lobo's Shelf Modification
Gator Saver Offline
Loc: Lakeland, FL
I just finished mine. i love it.
Allen Powell
Gator Saver
2000 Blue SE 4x2
Real Men Wear Kilts
Real Men Wear Kilts
Member number #112 Aug. 20, 2000
#70947 - 27/05/01 11:35 AM Re: Sgt_Lobo's Shelf Modification
2kxtra Offline
Loc: Woburn, MA
Sarge,
Nicely done! I've been trying to figure out a similar setup to stow stuff like my life jacket, bike stuff, etc. You know, the crap that just gets in the way but you don't want to leave it home either. Any idea if a bike will still fit under there? I have an interior rack so saddle clearance might be a problem for me.
Thanks to you and *paul for posting these. Now I have a few ideas to work from.
Rob
"not all those who wander are lost" -J.R.R. Tolkien
later, Rob
#70948 - 27/05/01 11:46 AM Re: Sgt_Lobo's Shelf Modification
Walrus Offline
Loc: Waterloo, Ontario, Canada
Originally posted by Gator Saver:
Care to elaborate? Details, pictures..
Mike.
01 XE Auto - Solar Yellow
Mike.
06 OFFROAD - Knight Armour
#70949 - 27/05/01 07:25 PM Re: Sgt_Lobo's Shelf Modification
Sgt_Lobo Offline
Sorry, I'm not sure if a bike will fit or not. I carry mine on a hitch mounted rack.
Sgt_Lobo
2000 4X4, SE, White
Sgt_Lobo
#70950 - 04/06/01 01:49 PM Re: Sgt_Lobo's Shelf Modification
Walrus Offline
Here's a picture of how I did my rack. 4'x16" shelving from Home Depot. Same as what onemadfool used, but I mounted mine with the lower front bar of the rack in the roof tiedowns, which results in it being closer to the roof.
[img]http://image.photoloft.com/opx-bin/OpxFIDISA.dll?src=/photoloft/asset16/2001/06/04/6976/6976495_0_9567.fpx,0,0,1,1,640,480,FFFFFF[/img]
You can see in the left corner how it sits into the tiedown. I used a bungee on the back, that way I can pull the back down and get stuff out of there without having to detach/unfasten/unhook anything.
Mike.
[This message has been edited by Walrus (edited 06-04-2001).]
Mike.
#70951 - 04/06/01 02:14 PM Re: Sgt_Lobo's Shelf Modification
mindie Offline
Loc: Portland, OR
Originally posted by Walrus:
You can see
Um, I can't see...
Mindie - AIM: mindiejoynt "I believe in what I see, I believe in what I hear. I believe that what I'm feeling changes how the world appears."
#70952 - 04/06/01 02:34 PM Re: Sgt_Lobo's Shelf Modification
Walrus Offline
Um, I can't see...
Try it again.
Mike.
Mike.
#70953 - 04/06/01 03:25 PM Re: Sgt_Lobo's Shelf Modification
xterrabull Offline
Loc: san jose, CA, USA
Walrus,
the picture shows up fine; Mindie I believe is trying to say the the picture is not close-up enough to show how the shelf is mounted to the forward tie down--and I agree .
#70954 - 04/06/01 04:00 PM Re: Sgt_Lobo's Shelf Modification
rbbarker Offline
Loc: Houston, Texas
What exactly is the shelf made of? What's the approx weight? That's a great idea and it turned out really good. Congrats!
--Boyd
Page 1 of 3 1 2 3 >
