0 registered (), 226 Guests and 0 Spiders online.
#97432 - 23/06/07 05:14 PM X got stuck in 4WD
Hey, I hate to interupt the lever envy, you all are funny! Question;..I had my 2007 in 4WD, then I stopped, switched it back, and it wouldn't really go back to 2WD, at least according to the 2WD-4WD idiot light. I tried going between 2WD-4WD a few times, gave up and started toward home, after about 4-5min. the light went back to 2WD. Any thoughts?? I haven't been out 4WDing since then,...just a freak thing? thanks for any ideas,lj
#97433 - 23/06/07 05:28 PM Re: X got stuck in 4WD
Did you back-up after swithching to 2 WD?
#97434 - 23/06/07 05:39 PM Re: X got stuck in 4WD
Are you suppose to back-up?? I never heard that before:-)!
#97435 - 23/06/07 05:53 PM Re: X got stuck in 4WD
Look at your manual, you need to back up about 10' or so.
#97436 - 23/06/07 06:28 PM Re: X got stuck in 4WD
Mine gets stuck about once a month or so. :rolleyes:
Almost as often as the thing throws SLIP and VDC OFF lights. [Uh Oh !]
#97437 - 23/06/07 06:57 PM Re: X got stuck in 4WD
Thanks, you guys, I feel alot better now. I swear I read the manual and missed the backing up thing. Thanks again,lj
#97438 - 23/06/07 07:27 PM Re: X got stuck in 4WD
Rickster43 Offline
Loc: San Antonio,Texas
Thank God for the Classic Little Lever...
Your Personal CADD Monkey...
#97439 - 23/06/07 07:51 PM Re: X got stuck in 4WD
I'm confused now...
On the new X's....they still have to back up to disengage?
#97440 - 23/06/07 07:53 PM Re: X got stuck in 4WD
X2
You can get underneath there and beat the shit out of it if it gets stuck with a BIG F*(KING HAMMER!!!! [Too much XOC]
#97441 - 23/06/07 08:22 PM Re: X got stuck in 4WD
My light stayed on once or twice from getting stuff stuck in the sensor after off roading a couple of times. Make sure thats not the problem...
#97442 - 24/06/07 07:34 AM Re: X got stuck in 4WD
Originally posted by TJ:
I'm confused now...
No, you don't...hub flange vs auto hubs.
Not to mention that, when I had my auto hubs, I would shift out of 4wd and the light would turn off (this is without backing up). Granted my hubs were still engaged, but it was no long in 4wd.
#97443 - 24/06/07 07:54 AM Re: X got stuck in 4WD
How about an 03 4x4 super charged, do I have to backup, I never have! Now I am nervous
mark
#97444 - 24/06/07 08:07 AM Re: X got stuck in 4WD
mark
yes you do
#97445 - 24/06/07 08:18 AM Re: X got stuck in 4WD
Not to sound "snooty" but aren't the operating instructions on the visor directly above your head??? mad
#97446 - 24/06/07 09:21 AM Re: X got stuck in 4WD
Hey! Now I was worried. The instructions are on the visor!!, what a moron I am! I went out and double checked and at least on my 07, there is a bunch of blah blah about advanced airbags and the possibility of roll-over, but nothing about the proper way to disengage 4WD. wink
#97447 - 24/06/07 11:36 AM Re: X got stuck in 4WD
I did recheck the '07 manual and I still can't find any mention of backing up after taking it out of 4WD. It does say to have it in neutral when you switch it from 2wd to 4wd and back but nothing about reverse, but I will definitely do that in the future. Thanks
#97448 - 25/06/07 12:09 AM Re: X got stuck in 4WD
PaulXyZ, the Slip and VDC lights will illuminate when you are in 4-low with the locker on.
#97449 - 25/06/07 12:31 AM Re: X got stuck in 4WD
Put on manual hubs and you won't have to back up. laugh Applies only to pre '05 Xs.
#97450 - 25/06/07 06:44 AM Re: X got stuck in 4WD
Yeah - my understanding was that the 00-04's needed to back up, and the '05+'s do not.
The above posts about the hubs and shafts and flanges, etc, were why, for each...and for the new ones....the neutral position between was important, etc.
So - Pre-'05's - NEED to back up to get out of 4wd...but...
...you can leave the hubs engaged, and still be in 2wd, so if you NEED 4wd, you're already engaged, and don't need to ROLL FORWARD more to be in 4wd.
IE: If in 2wd, and you hit a bad patch of mud and get stuck, and THEN shift into 4wd...and the gears didn't mesh yet if you can't roll forward a bit more...unless you didn't disengage the hubs by backing up after going back into 2wd.
(Don't back up after putting it in 2wd if expecting 4wd use later that drive, etc...)
#97451 - 25/06/07 07:33 AM Re: X got stuck in 4WD
Right. We don't backup to disengage 4WD, we disengage 4WD by putting the selector in 2WD. We backup to disengage the hubs (or drive if it was in Reverse when shifted back to 2WD).
On slippery roads in the winter, I start in 4WD and shift back in 2WD so that the hubs are engaged should I need 4WD later during that drive.
But this has nothing to do with the original post since he drives a Gen2 and this applies to Gen1.
#97452 - 25/06/07 10:00 AM Re: X got stuck in 4WD
I have the new 2005 with the dial on the dash. First time out, I put had it in 4WD Hi and went to Low. Since I did not read that part in the manual, I turned the dial, slammed in into drive, and the whole transfer case reset itself to 2WD leaving me perplexed on steep hill climb. Since then, I've read the manual and have had the X in 4WD low many times. what I've noticed is that you have to put it in Nuetral and wait for the solenoids to finish there clunking. The light will start flashing, meaning that the transfer case is out of lock, but the front end has not diengaged. Sometimes it takes a 100 feet for it to loosen enough for the springs to disengage it, or I will roll back in Nuetral a couple of feet and that usually does the trick. No worries and nothing to be alarmed at. I've had both the old X lever and now the new X dial. Both are very good and solid off road.
#97453 - 25/06/07 01:11 PM Re: X got stuck in 4WD
With the 05+:
You can shift between 4hi and 2wd on the fly (under 60 (or so) MPH). There is nothing special you have to do beside turn the knob. Some times it will take until you stop to come out of 4wd as you have to relieve the stress on the gears before they can change.
To change into 4Lo. Come to a complete stop with the foot on the brake. Place the vehicle in Neutral (not park), switch into 4Lo. Put vehicle into drive (or one of the lower gears depending on the situation) and start driving.
To get it out of 4Lo, you have to do the same steps. Stop, foot on brake, knob to 4hi or 2wd, put vehicle in gear...drive way. Just like before, someone times it does take a short while to disengage.
#97454 - 25/06/07 01:38 PM Re: X got stuck in 4WD
It is probably not unlocking because the drivetrain is bound up. Backing up or inducing some wheelspin just before taking it out of 4WD will unbind the drivetrain and allow it to disengage.
#97455 - 25/06/07 05:22 PM Re: X got stuck in 4WD
If have shifted out of 4wd on the fly and some times the light goes out and some times it flashes but the sure fire why to get it out is to stop, back up a feet or two and all is well.
#97456 - 25/06/07 07:08 PM Re: X got stuck in 4WD
Yeah I know but what about in 2-wheel drive after leaving the car locked in a locked garage? wink
Mine comes on and off at random about once or twice a month. I'll drive to the mall, park, and come out and the lights are both lit and won't go out. The indicator (and butt dyno) say that the truck is in 2-wheel drive. Stopping and starting the truck has no effect and neither does actually putting the truck in 4WD and locking and unlocking the diff ... and the weather is so dry I don't think the truck has been wet once since I bought it in September when I crossed the Mojave road.
I've bought a ScanGaugeII to see if it's throwning codes that disappear by the time I get it to the dealer but last time it happened - no codes.
The first couple of times it happened I was worried. Same with the first couple of times it got stuck in 4WD low. Trying to drive faster than 25 mph on pavement ain't possible when stuck like that which makes it a real concern.
