#102461 - 31/03/03 05:31 PM transfercase
mattL Offline
hey im just wondering if they make a transfer case for a xterra to turn a 4x2 into a 4x4. If they do could someone give ma a link.
Matt
#102462 - 31/03/03 05:53 PM Re: transfercase
XPLORx4 Offline
Loc: San Jose, CA
That's kind of a funny question. You know, a 4x4 is really just a 4x2 with a transfer case and some extra parts. There isn't a "special" transfer case that you would need. But you'll need a lot more than a transfer case to convert your 4x2 into a 4x4!
For starters, you'd need:
transfer case
shifter
front differential, including axleshafts and driveshaft
new (shorter) rear driveshaft
Plus, if you have a 4-cylinder, there might be a lot of other issues mating the transfer case to the transmission.
You're probably better off trading in the 4x2 for a 4x4 than trying to convert.
4x4 in uppercase is $X$!!!
#102463 - 31/03/03 08:51 PM Re: transfercase
Craigs_Tonka Offline
Loc: Phoenix, AZ
WHY? confused By the time you are done buying all the parts and paying for the labor, you could have easily traded up to a 4x4 with money left over. :rolleyes:
For shits and giggles, lets see what you would need:
- Transfer case
- Front drive shaft
- Rear drive shaft
- Front differential
- Right and left half shafts
- Hubs (manual or auto locking)
- Crossmember (not included on 4x2's)
- Labor to R&R all the parts listed above.
eek eek eek
Even if you got these parts from a junkyard or bought a totaled truck, you are talking several thousand dollars. By the time you start adding labor to all of this, your total bill would be ridiculous. [Uh Oh !] [Crybaby] frown
I wouldn't even consider converting a 4x2 to a 4x4 with stock front drive. If you were adamant to make it a project vehicle, then you might just as well buy a solid front axle and put in coils or leafs up front so you could lift it higher than 3". Although it would still be cheaper to start with a 4x4 to do a SAS (solid axle swap) since the transfer case is already there.
www.azxterraclub.com
My Photos
#102464 - 31/03/03 10:52 PM Re: transfercase
You need a new transmission rear case too, since they are different. The 2WD just outputs to the driveshaft, the 4WD mates to the transfer case.
Moderator:  socalpunx
