#102987 - 23/10/06 02:06 PM Shut off
Does any-one know how to make it where the xterra doesnt shut off at 95MPH?
#102988 - 23/10/06 02:23 PM Re: Shut off
Warning: Potential flaming suspect above. [LOL]
Anyway, honestly, there is a reason why a 'BRICK' can only go 95 safely. As far as removing it, I'd say it's probably hardcoded into the ECM/PCM. Maybe an aftermarket chip????
MGJ
#102989 - 23/10/06 03:00 PM Re: Shut off
MGJ
Can I do it my-self? or would it be just as cheap to let someone at a shop do it?
#102990 - 23/10/06 03:08 PM Re: Shut off
#102991 - 25/10/06 01:41 AM Re: Shut off
i get 100mph out of mine [Finger]
#102992 - 25/10/06 05:35 AM Re: Shut off
please fill out the organ donor part of your license after you figure out how to get past 95 mph to pass on whatever's left to someone that needs it.
[Save the fine unicorns]
#102993 - 25/10/06 08:06 AM Re: Shut off
I mean...if you kill yourself that's bad, yet it's your own business. If you lose control, jump the median and crash head on into a mother of 5 driving a geo metro - well, that's other people's lives, you know?
There are 2 reasons for the governor at 95mph. One is the aerodynamics of the vehicle (or lack thereof), another is the limit of tires. At higher speeds the construction of the tires is not able to withstand the centrifugal force that the spinning tire creates and it literraly rips itself apart. Where do you think most high-speed crashes come from? It's mostly lost control due to exceeding the limits of the tires.
#102994 - 25/10/06 08:42 AM Re: Shut off
GrayHam Offline
Yes.
Don't drive that fast, Speed Racer.
#102995 - 25/10/06 08:44 AM Re: Shut off
Lightning Offline
Loc: High Point, NC
Those organs most likely aren't goingto be much use to anyone else either at that speed.
'00 4x4 V6 XE
#102996 - 25/10/06 10:42 AM Re: Shut off
get an Rx8or some other kind of car if you want some speed, likes someone said earlier, there is a reason why a brick can only go 95 mph!
#102997 - 25/10/06 05:22 PM Re: Shut off
zip zop zippity zoo
#102998 - 25/10/06 10:53 PM Re: Shut off
i've had a pickup truck and now an xterra but i can't get the 5.0 V8 out of my system from my T-bird and driving my dads Acura NSX often doesn't help as well :rolleyes:
Moderator:  socalpunx
