137
#103883 - 04/01/05 01:26 PM
Photo of Tbar crank
Does anyone happen to have a photo of where the bolts to crank the T-Bars are..? Im a Turbo guy and these SUVs are new to me..lol. If you tell me its directly behind the right rear whos-its-what, next to the center cap cluster thing-a-majig I seem to get lost...a Picture is worth a thousand words!!! Thanks!
#103884 - 04/01/05 01:47 PM
Re: Photo of Tbar crank
#103885 - 04/01/05 02:10 PM
Having read and (I belive) understood this, if the bolts are not frozen, shouldn't it take about 15 minutes to do?
Am I missing something, or should this be cake?
#103886 - 04/01/05 02:16 PM
It should take about that long per side using jacks & stands. Always releive the pressure before adjusting the bolts, makes it ALOT easier.
Most people forget that there are 2 nuts on top of the bolt and you need 2 wrenches to make it work closed end wrenches are your freind here. Put one on the bottom nut and then loosen the top nut.
#103887 - 05/01/05 04:24 AM
If you want to save yourself some trouble now, hit the nuts/bolts with nut blaster/penetrating oil a week a head of time, every day, until you do the adjustment. When you finally have the nuts/bolts cleaned and ready for re-assembly...coat the threads with anti-seize compound...makes the next time take 5 minutes.
#103888 - 05/01/05 09:18 AM
TJ do you own stock in nutblaster? you push it in almost every post.
#103889 - 05/01/05 09:36 AM
I should go buy stock.... Its just that every frigging thing under the X I have ever worked on is rust welded...and the stuff works. (I do also say "/penetrating oil" when I say nut blaster though...so If I buy stock...I'll drop that part.
#103890 - 05/01/05 11:32 AM
Loc: In a Bar near YOU!
you sure its nut blaster and not ball buster?
.:SpaceMonkeyMafia:.
#103891 - 05/01/05 08:38 PM
After you get done might want to get your alignment checked or you might have some extra wear on the outer edge of your front tires. Other than that, it's as simple as it sounds
#103892 - 07/01/05 03:31 PM
Hey thanks guys! I was just tryin to find the page that showed the step-by-step, couldnt find it in a search!...I appreciate it!
