137
#106684 - 30/11/05 03:26 PM
SAS'ing
Time on the dealer warrenty is comming to an end and I am looking at my options. All said and done, how much did it cost you to do an sas? Im trying to decide if I want to do a 3" with the IFS, which will require a steeting upgrade or go with a sas an get rid of a lot of problems that the IFS has with it.
#106685 - 30/11/05 03:48 PM
Re: SAS'ing
Originally posted by JeffW: Originally posted by Max Kjellin: [b]Cost...? Really would like to know. Thanks For SAS?
$5K out the door (if you do the work yourself)[/b]
#106686 - 30/11/05 05:10 PM
Re: SAS'ing
Loc: Torrance, CA
Cost will vary depending how much you pay for the axle, what options, gears, etc, you use and how much work you’re doing yourself? Figure 4-6k depending on what you get. For the Core Swap parts (3.7k) - axle ($1.8k for the CALMINI SAS kit, $800 for the fox coil-overs complete, $400 front CV driveshaft, $300 rear spring pack, $400 anti rock sway bar) Granted I spent ~ 6k but then again I went from stock to dual locked SAS over a weekend Changed gears, new tires, and added some other HD upgrades such as Long Field Super U-Joints and a RockCrusher D44 Diff Cover/skid that are optional.
SCCX Home Page
#106687 - 30/11/05 05:15 PM
Re: SAS'ing
#106688 - 30/11/05 05:47 PM
Re: SAS'ing
Loc: Torrance, CA
Originally posted by steelX: $3700 for the axle? Did you miss the - (minus) axle part I paid $150 for my 85’ waggy axle but then replaced the Inner, Outer Wheel Bearing & Races, Rotors, Calipers, Pads, Inner/Outer Passenger Tie-rods and Drive Outer, and ball joints. Including the warn hubs and Yukon 5.13 gears ~ $500 for the the front axle minus options (ARB locker, Super U-Joints and a RockCrusher D44 diff cover)
SCCX Home Page
#106689 - 30/11/05 07:45 PM
Re: SAS'ing
right , so its $3700 for the axle after total rebuild? i read some where that the axle was rebuild for about $1700, so im trying to figure the other $2000 oh yeah : Did you miss the - (minus) axle part you dont have to get all snooty about it.
#106690 - 30/11/05 08:34 PM
Re: SAS'ing
Loc: Torrance, CA
Originally posted by steelX: right , so its $3700 for the axle after total rebuild? i read some where that the axle was rebuild for about $1700, so im trying to figure the other $2000 No $500 for the axle total after I rebulit it. $3700 is for the parts as noted above ($1.8k for the CALMINI SAS kit, $800 for the fox coil-overs complete, $400 front CV driveshaft, $300 rear spring pack, $400 anti rock sway bar)
SCCX Home Page
#106691 - 30/11/05 09:24 PM
Re: SAS'ing
I'll have to think about it some more, but looks well within reality for me. By the time the warranty is up I should be able to do the axle rework.
#106693 - 01/12/05 06:11 AM
Re: SAS'ing
When the time comes Im going to have to spread that mod. out. THat amount of money will be a hard pill for my wife to swallow. It will be realized though, I first have to get a place build the axle seeing as how my 4 kids have taken over my garage with all there ride ons and such, wouldnt trade them for the world though.
#106694 - 01/12/05 08:51 AM
Re: SAS'ing
Airbornenurse, I really think you should do the SAS now. That way you can sell me the SLR front lift parts you have.. for cheap.
#106695 - 01/12/05 02:57 PM
Re: SAS'ing
I think I'll go treasure hunting in French Lake Auto Yard in a few weeks. Carlton, help would be great! I'll let you know when I get going on it. Looks like your signature got to me.
#106696 - 01/12/05 03:23 PM
Re: SAS'ing
Originally posted by skaggs396: Airbornenurse, I really think you should do the SAS now. That way you can sell me the SLR front lift parts you have.. for cheap. Well the price will all depend on how much I lay down on the mod. Of course I just recently got the 3''SL and that was a hard and tedious sale campagian.
#106697 - 08/12/05 05:06 PM
Re: SAS'ing
hey i am just curious, how much more is it to SAS an Xterra, as opposed to putting the Total Chaos Fabrication Long Travel Suspesion lift on. In other words, is it a better deal to SAS than go with the Total Chaos Fabrication?
#106698 - 08/12/05 06:12 PM
Re: SAS'ing
Loc: Torrance, CA
Originally posted by Xterrarob04: hey i am just curious, how much more is it to SAS an Xterra, as opposed to putting the Total Chaos Fabrication Long Travel Suspesion lift on. In other words, is it a better deal to SAS than go with the Total Chaos Fabrication? Cost wise they are close if you consider the TC steering componets with the LT. Other than that its a bit like apples vs oranges They both use coil-over shocks up front with different design goals in mind. The TC kit is set up for BAJA running, higher speed desert terrain, jumps, whoops, etc. Coils are firmer (500-600lbs) & better suited for sand running and faster type four wheeling . More emphasis is placed on compression and rebound travel rather than articulation with a ~ 3" lift For the CALMINI SAS kit the coils are softer (300lbs dual rate) and the whole setup gets more articulation. More emphasis is placed on wheel travel and droop. Better suited for rock crawling, slower type wheeling with more lift 5". Both are more reliable,stronger than stock, work very well and make sweet upgrades
SCCX Home Page
#106699 - 08/12/05 06:18 PM
Re: SAS'ing
Originally posted by Xterrarob04: hey i am just curious, how much more is it to SAS an Xterra, as opposed to putting the Total Chaos Fabrication Long Travel Suspesion lift on. In other words, is it a better deal to SAS than go with the Total Chaos Fabrication? Apples and oranges. If you wanna run the Baja 1000, go with TC. If you want to rock crawl, do the SAS. Everything in between will be a tradeoff. ........ My Dana 44 is sitting in my garage with gears and ARB. SAS is better for my purposes.
