Originally posted by Ebeauchea:
I'm actually surprised what you all paid for junkyard axles..expensive. I wonder how many had the diffs blown up...I'm going to be buying some Dana 44 and/or Dana 60 front axles soon for a decent price. I'm wondering if I can get that to fit but probably way too wide.
Well Basically what you are buying is the housing if it is a stock axle right out from a Wagoneer. Here are the issues with the stock axle.
* Ring & Pinon will not match the Xterra Ring and Pinon, so you have to buy new ones (ring and pinons in the waggys was less than 3.7 you need 4.56 or above).
* The carrier in the stock axle will NOT work with the new Ring & Pinon (stocks came with a 3.73 & down carrier so you need the 3.92 and up carrier).
* Most of the bearings and stuff will be easy to replace while having it pulled apart to regear so you just as well replace, bearings, seals, calipers and the disks if they have any significant wear.
It comes down to all the parts that could be damaged need to be replaced. And no WAY am I buying a new D44 $$$$$$$$$$$, and then still have to regear.
I looked around really hard to find a built up axle, Jeff got a smokin deal on his.
