Hopefully you are headed up in the FJ? ...actually, you would be okay because you have underside armour. I can show you all where it is, but I don't think my rig will see that trail again until things get modified a bit more
When do we start going on runs to the Sierras? It should be happening soon.
If you have a fax I can send you details of the entire run complete with descriptions and waypoints, just give me a number and I'll fire it off. I wouldn't mind doing it again (with the exception of what they were calling Bronco Canyon, someone told me it was Largo, Lango--Marchino, machino something-or-other valley officially.) I especially want ot have a look at the petrogliphs--apparently they are dated back to a couple thousand years ago and there are a ton of them in the area.
The general area for Bronco is n39.20.049,w119.37.556 hard left into pinion trees, follow large power lines north, will get to abandoned ranch (Cottonwood Ranch) on the left. Continue north following power lines. There will be a faint track going to the right, n39.24.487, w119.34.181. Trail is rated 5++, large tires, lockers and Rubicon type experience required/(recommended :rolleyes: , my X made it albeit with some undercarriage character additions--I need a new oil pan, but hey you might miss that rock
) I can show you the way in, but will take a detour around that portion and walk back up the trail to check out the carnage-er-ah...fun
