#114186 - 22/01/04 05:36 PM Tcase gear installation
olebiker Offline
Loc: Novato
I searched...
Anyone have a suggestion for a shop/person to do the calmini gear set install in the bay area... preferably north bay. I will hand them the tcase.
Rock on!
Move the seat up Alice, so you can push the accelerator all the way down!
#114187 - 22/01/04 05:51 PM Re: Tcase gear installation
KaiOtiK Offline
Loc: Mountain View, Ca.
Hey Olibiker,
Rear End Specialties should be able to handle it.
http://www.rearendspecialties.com/
"Just A Thought"
Best Regards,
Andy -AKA- KaiOtiK
"rEaLiTy iS tHe ExIsTeNz Of CoUpLeD vIsUaLiZaTiOn"
#114188 - 22/01/04 06:10 PM Re: Tcase gear installation
Huey Offline
Loc: Hayward, CA
Originally posted by KaiOtiK:
Hey Olibiker,
"Just A Thought"
Actaully I don't think they can do it. Rear End Specialties only works on differnentials.
Gary, have you tried contacting Marty? Another option may be to post this question on Pirate4x4 or on a Yota board, as they seem to do these upgrades more frequently then we do. You just need to find a shop that is confident enough to handle a Japanese t-case. Also let them know that you have detailed install directions (which include grinding the t-case for clearance). Good luck! smile
-Huey
#114189 - 29/01/04 02:33 PM Re: Tcase gear installation
olebiker Offline
Loc: Novato
Marty,
Check your PM please.
Huey, who did yours? If I may ask...
smile
Rock on!
#114190 - 29/01/04 08:22 PM Re: Tcase gear installation
Huey Offline
Loc: Hayward, CA
Originally posted by olebiker:
Marty,
smile
I realy have no idea of the guy's name. Marty knows him personally as they are good friends and I only met him briefly when I droped the t-case off. Drop Marty an email at his webTV address, I think that's the one he checks most (I'll PM you the info). BTW, the shop should be relatively close to you (Santa Rosa).
-Huey
#114191 - 02/02/04 06:15 PM Re: Tcase gear installation
Gary,I've left my friend a voicemail the other day and haven't heard back. He now works in another garage and I haven't seen him in 2 months.
#114192 - 02/02/04 07:58 PM Re: Tcase gear installation
olebiker Offline
Loc: Novato
Thanks Marty,
If you hear from him, I'd appreciate talking with him...
Rock on!
#114193 - 03/02/04 09:20 PM Re: Tcase gear installation
Gary, I finally got ahold of Danny (the mechnic). He now works at another garage and doesn't think that his boss will let him do the work. I should be seeing him in a few days to see if he can do it thorough the business and get a price. I hope you are just planning on taking the transfercase out and delivering it. Otherwise it can be a lot more expensive.
#114194 - 03/02/04 09:28 PM Re: Tcase gear installation
olebiker Offline
Loc: Novato
Thanks Marty,
Yes, I was planning on handing over the tcase and helping with the install if possible.
Rock on!
#114195 - 18/02/04 06:03 PM Re: Tcase gear installation
olebiker Offline
Loc: Novato
This is the last post on this subject....promise!! [Too much XOC]
Marty, did you find anything out?
Anyone want to share a Tcase gear mod weekend?
Rock on!
#114196 - 18/02/04 06:44 PM Re: Tcase gear installation
NthLJ Offline
Loc: Reno, NV USA
Would such a weekend include the parts [Laughing] [LOL] ?
Charlie
#114197 - 18/02/04 08:22 PM Re: Tcase gear installation
Huey Offline
Loc: Hayward, CA
Yikes, hope Marty can get a hold of the guy for you Gary.
Anyways here are a few hints on pulling the t-case out of the truck:
-drain both the transmission and t-case of all oil
-jack up the front of the x and place two jackstands under the frame
-pull both t-bars out (you will need the space)
-remove the cover in the cabin for the tranmission
-unplug the 3(?) electrical connecter plugs
-remove the front and rear driveshafts (remember to mark them so that they re-align during install)
-now start removing the bolts that hold the t-case to the trans (some will require access from inside the cabin)
-once all the bolts have been removed, lightly support the t-case with a jack (preferably a trans jack, but a floor jack will do in a pinch)
-then carefully pry the t-case from the trans with a screwdriver. you will need an oil pan as there will still be a bit of oil that will leak out.
-slowly pull the t-case toward the back the truck till you can claer the input shaft
-here's the tricky bit, carefully rotate the t-case out from below the truck
**having a second set of hands will make life easier, but I pulled mine myself while swearing and yelling. [LOL]
Those directions are quite simplified, but you will find it quite straight forward once you start. Also having a good selection of extensions for your ratchet will definately help.
-Huey
#114198 - 19/02/04 09:55 AM Re: Tcase gear installation
olebiker Offline
Loc: Novato
Thanks for the input guys....
Rock on!
Moderator:  Huey, slamson00
