From what I remember from when I had your exact set-up is that without a hitch, there is really no good place for recovery points. In a worst-case scenario, you probably could get by with putting a strap around your rear leaf spring shackle, but not for a heavy recovery, and not more than once or twice. If you plan on going out enough to get stuck on a semi-regular basis, I would at least invest in an aftermarket hitch. They bolt right on (with or without frame stiffeners), and it's an automatic (safe) recovery point. Just trying to save you moeny and frustration later down the line. Hope this helps.
